k all motor gurus..... what is the point of no return when you cant drive your car
what makes a motor so bad *** that you cant drive it on the streets and you cant go on road trips with it?
well i want to stay all motor, hit like mid 12s but still be able to drive around like ussual, and still go on road trips, right now i have a jdm itr motor, what route would you guys go?
you can still drive around a really high compression motor with big cams, although it won't idle well and it will use lots of gas
usually they got hotter too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddiecut »</TD></TR><TR><TD CLASS="quote">well i want to stay all motor, hit like mid 12s but still be able to drive around like ussual, and still go on road trips, right now i have a jdm itr motor, what route would you guys go?</TD></TR></TABLE>
same here
same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddiecut »</TD></TR><TR><TD CLASS="quote">well i want to stay all motor, hit like mid 12s but still be able to drive around like ussual, and still go on road trips, right now i have a jdm itr motor, what route would you guys go?</TD></TR></TABLE> same here too
its not a matter of power
its when stuff breaks more often from the extra miles you put on it
its when u get 12mpg cause you are always driving it hard all the time
when u are worried someone will steal it
when the problems outweigh the benifits
being fast isnt easy, well it can be easy if you have lots of money
Reasons why my car isn't a daily driver:
#1 I'm scared of getting ganked
#2 900lb Rear Springs
#3 No Radio\Speakers
#4 Scared of getting smashed by a big truck and getting no insurance money.
#5 Scared of getting ganked x2
Suprdave
Suprdave
when you know the cops will pull you over and give you over 2k worth of tickets...
when the motor, and power you have- scare the crap outta everyone that rides bitch
when you race every car, cause you know you won't lose
when you become mentally dangerous.....
As far as the motor goes, when you have a really stiff clutch, really high compression, big cams, very light flywheel, etc...the car can be difficult to be smooth with...u literally drive 2nd gear, to 4th, to 5th in like 5 seconds. The majority of time you can leave it in 5th and just accelerate around w/o problems.
More than anything, what gets annoying is not motor stuff, but chassis, being gutted is no big real, neither is a roll bar, but buckets seats and harnesses are tough to deal with everyday, so is a full-on roll cage, so is no a/c and no under fans, stiff motor mounts, stiff clutch, loud exhaust, etc.
my only things are it being loud and the clutch pressure plate being too stiff.
everything else makes it "fun"
ie: fast, gas guzzler, no interior, no traction, etc, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER »</TD></TR><TR><TD CLASS="quote">when it requires race gas</TD></TR></TABLE>
i've seen alot of people in so cal have no problem filling up 110 in their backyard out of their 55 gallon drums haha.
Thank god i fill up with 87
ya i see what you are all meaning, i mean if i put a dtr header on, some pretty meaty cams, i should be makin some ok power tuned with hondata, so it wont be that big of a deal on the gas part but i was just wondering how hot everything gets and how hard it to be able to drive a motor like that forawhile at one time.....
thanks tho guys
thanks tho guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 »</TD></TR><TR><TD CLASS="quote">when you know the cops will pull you over and give you over 2k worth of tickets...
when you become mentally dangerous..... </TD></TR></TABLE>
LOL thats fer damn sure .
or when you gotta a 5 gallon fuel cell and you guage your range by the amount of miles on the odometer
or when the fuel pump is noisier than the stock honda doorspeakers
A motor is a motor.. it doesnt know the difference between beeing driven hard on the street or on the track.. IF it was built right using correct tollerances then Yes any motor can be driven on the street.. If the motor lasts 70miles straight without a hitch, then it can go 300 miles etc.. Having a built motor doesnt make things harder to drive on the street, it just adds more on the to do list to maintain the car, If im building a motor for street and occassional track use, then I use oem pistons bottom line.. If its a more of a weekend car then thats another issue. but for the most part you can drive any motor on the street. Basically there is really no point of return but your wallet, insurance and driving record..
Max-
Max-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LuckyRacing »</TD></TR><TR><TD CLASS="quote">A motor is a motor.. it doesnt know the difference between beeing driven hard on the street or on the track.. IF it was built right using correct tollerances then Yes any motor can be driven on the street.. If the motor lasts 70miles straight without a hitch, then it can go 300 miles etc.. Having a built motor doesnt make things harder to drive on the street, it just adds more on the to do list to maintain the car, If im building a motor for street and occassional track use, then I use oem pistons bottom line.. If its a more of a weekend car then thats another issue. but for the most part you can drive any motor on the street. Basically there is really no point of return but your wallet, insurance and driving record..
Max-</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EG »</TD></TR><TR><TD CLASS="quote">LOL thats fer damn sure .
or when the fuel pump is noisier than the stock honda doorspeakers</TD></TR></TABLE>
Hahahahaha
Or when your car looks to good on jackstands and the motor looks to good in your living room
Hahahahaha
When you don't make enough vacuum to run power brakes.
I haven't had a stereo for over a year and you get used to it pretty quickly. You also lose any modesty when it comes to singing at stoplights.
From personal experience, weird **** breaks when you take a modified car on a road trip. I haven't made a clean trip to TX this year. Between an ignition wire, coil, and a flywheel gear ring that somehow came loose I've been stuck on the side of the road 3 times since summer began. If you don't mind doing an insane amount of maintenance and checking under the hood religiously, then you can take your car as far as you can handle it. Each person has a different level of patience. Figure out what your limit is and start pushing it.
You want to make road trips buy a stock car with a bumper to bumper waranty w/ road side assistants.
if you plan on building a sick *** motor for road trips get nation wide cell coverage and AAA platnuim and have a credit card (not maxed out). but for local putting around build what your pocket allows!! get sick with it. Methanol, off the header, spindle mount rear end, all the mb fiber glass products,fire breathing all motor beast!! oh and lexan everthing!!
