I got white smoke comming out my exhuast ..
Old Sep 27, 2003 | 10:39 AM
CityHunt3r's Avatar
Default I got white smoke comming out my exhuast ..
i got white smoke commig out my exhaust when im at idle.. wheni drive it disapears.. hmm any ideas??? i smell a lil fuel too no catalic convertor either
Old Sep 27, 2003 | 11:55 AM
iam7head's Avatar
Default Re: I got white smoke comming out my exhuast .. (CityHunt3r)
white smoke=burning coolant
check the cooling system
-voltage check
-pressure check
-coolant
-air in the systems?
also check the headgasket
Old Sep 27, 2003 | 03:49 PM
Kavehman's Avatar
if it plumes of white smoke that lingers in the air forever, then you have a problem. If the white smoke dissapears relatively quickly then its just water vapour
Old Sep 27, 2003 | 06:33 PM
CityHunt3r's Avatar
Default Re: I got white smoke comming out my exhuast .. (Kavehman)
well it disaperas after it lifts.. but u dont think its head gasket then? u can only see it when cars at stop. when i accel it disapers.. completely
Old Sep 27, 2003 | 11:46 PM
iam7head's Avatar
just replied your email, prepare for some reading
Old Sep 28, 2003 | 05:51 AM
NathanMorris's Avatar
Default Re: I got white smoke comming out my exhuast .. (iam7head)
sounds like water vapor for the most part
- Nathan
Old Sep 28, 2003 | 02:28 PM
-RedneckDave-'s Avatar
Working
that sounds like condensation and not coolant. Do you know what temp it is and the relative humidity when it does this.
Old Sep 28, 2003 | 02:43 PM
iam7head's Avatar
Default Re: I got white smoke comming out my exhuast .. (01accordv6)
https://honda-tech.com/zerothread?id=632076
Old Sep 29, 2003 | 12:29 AM
Gerhard_001's Avatar
Just pull the sprak plugs out, this is a quick way to determine what is going on in your engine. If it is a blown headgasket your plugs will be white due to the coolant burning in the combustion chamber.
Old Sep 29, 2003 | 05:47 AM
CityHunt3r's Avatar
Default Re: I got white smoke comming out my exhuast .. (Gerhard_001)
hehe no white stuff just a lil oil
Old Sep 29, 2003 | 11:13 AM
TomSlick's Avatar
It's gonna be water vapor--either condensation in the exhaust, or leakage from the head gasket (coolant). An easy way to tell the difference is to smell the exhaust (but not for too long... ). If it has a really acrid smell, it's coolant and you'll have to check the head for warpage and replace the gasket. If it just smells like exhaust, it's condensation.
Old Sep 29, 2003 | 06:36 PM
aaaallll04's Avatar
Default Re: I got white smoke comming out my exhuast .. (TomSlick)
the smoke is becuase your car is so FASSSST!
Old Sep 30, 2003 | 05:07 AM
CityHunt3r's Avatar
smells like.. gas hahah and man my car is so slow.. good lord how can i adjust timming for better performance???? or ignition or whatever u call it... i want to tune it up as best as i can before i do anything special to it..... what happens if u put spark plug wires in wrong firing order??????? anyone know????
tdizz07
Jan 14, 2010 09:04 PM
Bruce Banner
Feb 16, 2007 05:59 PM
94gsr18kid
Dec 28, 2004 07:22 PM
davejj40
Sep 30, 2004 12:36 PM
civictypenos
Aug 12, 2003 10:00 AM
