90 crx installed b16 what to do with 2 o2 sensors in header with one hole?
Old Sep 27, 2003 | 07:32 AM
turboex's Avatar
Default 90 crx installed b16 what to do with 2 o2 sensors in header with one hole?
Ok got 90 crx with b16, came with 2 o2 sensors in the upper part of header. my dc sports has only the lower bung. So how do i wire this? Thanks guys
Old Sep 27, 2003 | 07:48 AM
technician 419's Avatar
Default Re: 90 crx installed b16 what to do with 2 o2 sensors in header with one hole? (turboex)
only use the primary o2 the one with the cream colored plug. atthe ecu bridge if memory serves me correct pins c8 and c16. so that the ecu can read the primary and the secondary o2. one of the two spots will be blank so just pin it and splice to the other pin location
Old Sep 27, 2003 | 08:42 AM
b16_madman's Avatar
no, plug the lower bung with something ( i think spark plugs work, but might get in the way of the flow), and take your header to get two o2 sensor bungs welded just like the oem application.
@ least that's what ive heard from the past.
crxpwr1
13
Nov 26, 2007 12:29 PM
VTECengaged
Jan 25, 2007 07:26 PM
T_Rex
10
Jan 19, 2003 05:32 PM
