after intake manifold swap, engine won't rev. URGENT!!!
I put a y8 intake manifold onto my dx (d15b7) head and now the enginr will idle, but stall when revved. Why? Nothing seems to leak from anywhere and the motor sounds good. It won't rev. Please help. Thanks in advance.
any codes??
Did you get then furthest nut, underneath on the passenger side on??? I've seen people skip this because it's :hard to get to" and results in thrown rods(coolant in oil).
Check your TPS and MAP sensor plugs, maybe they were reversed.
OK. Thanks for everything. It was the IACV. I'm a retard and forgot to plug it in. Now the idle jumps up and down. Not a lot, but a little.
mesonerz
May 21, 2008 01:11 PM
mutantmopar
Aug 2, 2007 03:06 PM
