TODA Rings
Old Aug 25, 2001 | 05:49 PM
coquinn's Avatar
Default TODA Rings
Just curious if it is possible to use different rings w/ TODA pistons. I know that the compression ring that TODA supplies is a different size diameter than OEM. The oil ring to my knowledge is the same size. Just curious if any other manufactures rings will work w/ these pistons. Wasn't sure if only TODA rings would work because of the sizing TODA uses. Thanks for your time - current piston size is 81.50mm.
[Modified by coquinn, 9:54 PM 8/25/2001]
CaptivaBlueTeg
Nov 21, 2014 06:18 AM
black2001ITR
Nov 13, 2003 11:03 PM
jansenrw
May 2, 2003 10:48 AM
AllMotorITR
Oct 23, 2001 08:36 PM
ITR111
Sep 30, 2001 01:37 PM
