are drag launch springs streetable for a daily driver?
id suggest not running them. my car isnt a good example cause its ultralight but when i drive my car on the street its harsh. u hit a small bump and the whole rearend just jolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vadian »</TD></TR><TR><TD CLASS="quote">Are we talking bout the skunk2 kit? What are the spring rates on em?</TD></TR></TABLE>
900lbs spring rate for the rears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i need space »</TD></TR><TR><TD CLASS="quote">i had them, it was tolerable</TD></TR></TABLE>
I installed 750lb springs on my car and it was rough but tolerable until over 80mph and above 100mph slight bumps got a little scary.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 »</TD></TR><TR><TD CLASS="quote">I installed 750lb springs on my car and it was rough but tolerable until over 80mph and above 100mph slight bumps got a little scary.</TD></TR></TABLE>
I have heard that with that high a spring rate the rear wheels have a good chance of losing contact with the road if you hit a large bump. I would say you can run them on the street, depending what the roads are like, and how you drive. Just get ready for a potentialy rough, and anoying ride, and if the roads suck, and you have no control over your right foot when on public streets then maybe you should reconsider.
Yea same here
Yea same here
If you are willing to sacifice your ride. I had the NEUSPEED DRAG LAUNCH. It worked but i did get back aches after long rides. Personal experenice it works.
You get used to them in my daily driver. My 1st gen CRX is about 1800lbs with me in it and only 700 or so is on the back axle. I run 750 Ground control coilovers in the back. It sort of depends on how heavy your car is also.
jessevtec
Nov 14, 2003 04:38 PM
