Anyone use 26" slicks on an EG civic?
Old Sep 26, 2003 | 10:09 PM
EH2LS's Avatar
Default Anyone use 26" slicks on an EG civic?
Ok, I was playing around with this gear/speed calculator:
http://jadesupra.net/gears/index.html
and with an LS final drive and gsr gears (i have both trannies) my 4th gear on 26" tall slicks with a 7,500 rpm redline would be 132 mph. I plan to make around 450-500 whp or so on a 2300 lb w/ driver car
my question is, should I just go with a 24.5" slick (i have to go with a 15" slick if i want 26", m&h and mickey T make a 25" as the largest diameter on 13" wheels) or should I try 26" slicks, and does anyone run slicks that size?
what kind of body modifications do i need for my EG? fiberglass front end maybe
he's some possible combo's ive been playing with, all on 26" tall tires, 7500 rpm redline
4.26 final drive + GSR gears = 4th gear ends @ 132 (125 on 24.5")
4.40 final drive + LS gears = 4th gear ends @ 136 (126 on 24.5")
LS tranny stock = 4th ends @ 141 lol (130 on 24.5")
GSR tranny = 4th ends @ 128 (121 on 24.5")
Basically, do i want to stay in 4th as much as possible, or bite the bullet and just shift into 5th instead of losing time shifting from 4th to 5th as I'm going thru the traps and lose mph
right now on 300 whp, im trapping 118-119, so another 150-200 hp im most probably looking at 130+ at the very least right?
Modified by Response at 7:25 AM 9/27/2003
Modified by Response at 7:36 AM 9/27/2003
Old Sep 26, 2003 | 10:24 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Anyone use 26" slicks on an EG civic? (Response)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Response &raquo;</TD></TR><TR><TD CLASS="quote">what kind of body modifications do i need for my EG? </TD></TR></TABLE>
Dremel or a grinder wheel, hehe, Go to town.
Old Sep 26, 2003 | 11:43 PM
ninesecrx's Avatar
Default Re: Anyone use 26" slicks on an EG civic? (SIXTYdashONE)
Big F'ing hammer is most pro racers choice.
Old Sep 26, 2003 | 11:45 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Anyone use 26" slicks on an EG civic? (ninesecrx)
I prefer to call it BFH. So just FID and use the BDH.
art
Old Sep 26, 2003 | 11:46 PM
B20T's Avatar
Need a tail wind
Old Sep 27, 2003 | 12:10 PM
EH2LS's Avatar
Default Re: Anyone use 26" slicks on an EG civic? (B20T)
oook...so yes people use 26" slicks, or just use 24.5"
Old Sep 27, 2003 | 02:05 PM
jinxproof99's Avatar
New User
you can use the 26's for the gearing, but you'll probably net better times with a higher rev limit and 24's. 26's are used generally for over 550 to the wheels. usually for over 600 and mated to a b16 tranny. with the 26's, you'll need beefed up axles where as with only 400 to the wheels and 24.5" slicks, oem axles will work. but pertaining to your question about fitment, 26's will fit with minimal to no cutting on a 92-95 civic with coilover suspension. 400 to 500 hp, most people use 25's.
Old Sep 28, 2003 | 12:54 PM
EH2LS's Avatar
Default Re: Anyone use 26" slicks on an EG civic? (jinxproof99)
thank you very much
hey what size tires were u running when u smoked the tires in 4th that time against ur friend's z06 on the highway :tup: lol
Old Sep 28, 2003 | 01:07 PM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Response &raquo;</TD></TR><TR><TD CLASS="quote">thank you very much
hey what size tires were u running when u smoked the tires in 4th that time against ur friend's z06 on the highway :tup: lol</TD></TR></TABLE>
i think i was in 3rd........we were going about 70. they were 205/50/15, nitto drag radials. they suck as a tire.
Old Sep 28, 2003 | 03:52 PM
EH2LS's Avatar
ah well still impressive haha..i had 195-50-15's this year, i wasnt a huge fan
carbon fiber coupe
May 29, 2015 04:33 PM
allanonjj
Nov 14, 2005 06:14 PM
1 2 NV
Aug 28, 2004 07:58 PM
1 2 NV
Aug 17, 2004 05:17 PM
jeremy.
10
Dec 24, 2003 03:58 PM
