2000SiR dash in 93 coupe
total pain.
one of the ff-squad.com guys has it done, maybe Dylan or Lee... it is aspoon cluster for an EK in an EG.. they say it was almost impossibly a pain and they would NEVER try it again.
ive got it in mine its a pain in the *** nothinf bolts up the metal support in the 94 is only over the steering column the si goes from one side to the other it can be done without the si support you need to heat the bar and bend it down so that the dash will fit right you will also have to make custom mounts to put it in there whenever you are going to do it , if you run into problems hit me up ill give you some info
1990t-rx
May 24, 2010 05:30 AM
O3DigitalBath
11
Dec 24, 2004 02:02 PM
Rukkus233
Dec 19, 2002 06:40 PM
