Mini me Distro?
Old Sep 26, 2003 | 05:56 PM
xmd's Avatar
xmd
Default Mini me Distro?
When doing a mini me is it a must to change the distro on the A6 to the y8?
I've wired the harness up and the stock distro sparks can i just leave it because it fits in the y8 head perfectly.
Or do i have to use the y8 distro?
My issue is i've wired the harness to accept a odb1 ecu and removed the resistor pack and installed new injectors yet the injectors dont work. i was wondering if it was because the ecu wasnt reading the crank angle sensors.. etc in the distro plug correctly.
-x m d
Old Sep 26, 2003 | 07:07 PM
phatrick2332's Avatar
i believe you still need the injector resistor box when u go obd1..you might wanna put tha back in before you fry ur injectors. And you do have to use a z6 dizzy if u went obd1. Ur dizzy's obd has to match ur ecu's obd...
Old Sep 27, 2003 | 09:51 PM
mattb16a1civic's Avatar
Default Re: Mini me Distro? (xmd)
you must use the obd0 (a6/si) distrbuter the teeth on the crank angle sensor are different.
Canadian_EF
Sep 21, 2010 08:29 AM
MAFDARK
Feb 26, 2008 09:36 AM
mr. carpenter
Apr 9, 2005 01:56 PM
dan89crxsi
Mar 25, 2005 09:50 AM
Wes90civic
Feb 22, 2004 07:25 AM
