Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Just received my 5pt. Have some *more* ?'s
Old Sep 26, 2003 | 04:28 PM
DsITR's Avatar
Default Just received my 5pt. Have some *more* ?'s
Ok guys, just received my 5pt harness from soloracer.com .
I also ordered the 5 additional eye bolts, and snap in adapter thingys??
Here are some pics
Here lies my problem..the uhh snap adapter thingies I ordered don't look like they are wide enough for the belts.
This is of course based on my assumption that the snap adapters, replace the end fastners on the belt, is this correct? Do I need to order wider snap adapters..
Any help is greatly appreciated
Old Sep 26, 2003 | 04:40 PM
civicrr's Avatar
Default Re: Just received my 5pt. Have some *more* ?'s (DsR)
Hmmm. I can't really tell if those are the 2" or 3" size from the pics.
When you do thread the belts thru the snap ins, the belt should be folded in on each edge. It makes it harder to 'tear'. You can see a picture of this on several sites. http://www.nasaproracing.com under rules, ccr has one. IIRC, Simpson's site, the SCCA site, and.....also have them. You also need to make sure to double back the belt on the slider. Make sure to use back up plates with the eyebolts. You should also install cotter pins in the snap's once they are installed on the eyebolts.
HTH.
added in edit: Did you get the hardware from Racers Wholesale? They also have instuctions, I think. Hopefully, you just didn't buy the eyebolts from the hardware store. They should be Grade 8 or better quality. I ask because all of the ones I have seen before have had the 'golden' finish on them.
Old Sep 26, 2003 | 06:21 PM
DsITR's Avatar
Default Re: Just received my 5pt. Have some *more* ?'s (civicrr)
I got the hardware from soloracer.com..They only show one type of snap adapter, so these must be the right ones.
http://soloracer.com/gforcesnaphook.html
So Im right in my assumption that the snap in adapters, replace the peace on the end of the harness?
also, the belt should be folded in? if so to what degree..
Old Sep 26, 2003 | 09:41 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
fold 'em... my sabelts came like this
Old Sep 26, 2003 | 09:45 PM
siisgood00's Avatar
New User
Default Re: Just received my 5pt. Have some *more* ?'s (SkyeC)
I like your riced our mirror.
Old Sep 26, 2003 | 09:48 PM
Floyd's Avatar
Fold 'em.
Good advice on the cotter pins. Never even considered it.
The eye-bolts you have may not be long enough for some of the mounting points with backing plates.
Old Sep 26, 2003 | 10:43 PM
DsITR's Avatar
Thanks Skye!
Ya, I had a feeling about the eyebolts..Ill have to see what happens w/the install.
Old Sep 26, 2003 | 10:44 PM
DsITR's Avatar
Default Re: Just received my 5pt. Have some *more* ?'s (siisgood00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siisgood00 &raquo;</TD></TR><TR><TD CLASS="quote">I like your riced our mirror. </TD></TR></TABLE>
lol, you should see the rest of it.. cant put em on the car, mirror will suffice.
Pr0jektLude
Jul 16, 2004 11:15 AM
TAGURIT
Mar 12, 2004 11:18 AM
Steve91
Oct 24, 2003 03:21 AM
Black R
Aug 7, 2002 03:45 PM
AllMotorITR
Feb 6, 2002 09:21 PM
