code 8
Old Sep 26, 2003 | 04:27 PM
Dancing is Forbidden's Avatar
Default code 8
A few weeks back I got a code 8, tdc sensor. Changed out the distribuor, everything was fine. Then a few weeks after that I put a DX head on the car. Immediately the distributor threw code 8. Jeez. So I put ANOTHER distribuor on, Immediately again code 8. WTF?!?!?! Anyone know what might be causing this? Thanks guys.
Modified by EF9_SiR at 2:12 PM 10/10/2003
Old Oct 10, 2003 | 10:14 AM
Default Re: code 8 (EF9_SiR)
Still going on damnit. The car is now running like crap, cutting out, missing, blah blah blah. BUT NOW I have an LS engine in the car and we changed engine bay harnesses. Could it be the Shock Tower harness? I guess Im going to **** around with it today. Anyone have any clues? Thanks guys.
Old Oct 10, 2003 | 10:16 AM
Spade's Avatar
Follow the lines as best you can looking for cuts.
Old Oct 10, 2003 | 10:42 AM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Still going on damnit. The car is now running like crap, cutting out, missing, blah blah blah. BUT NOW I have an LS engine in the car and we changed engine bay harnesses. Could it be the Shock Tower harness? I guess Im going to **** around with it today. Anyone have any clues? Thanks guys.</TD></TR></TABLE>
I would grab a digital multimeter and check for breakage in the wire.
Check the following wires:
ORG/BLU from the dizzy to the B13 pinout
WHT/BLU from the dizzy to the B14 pinout
Old Oct 11, 2003 | 11:08 AM
OK so I took the plug off the distributor and checked with an ohmmeter. It was at 430(i guess ohms) which is in spec. Haynes said between 350 and 700. So that tested ok. I hooked it back up and tested at the ECU plug. It tested about the same there (i think it was 409). Anyone have any idea why it would the cel comes on periodically? Thanks guys.
Old Oct 11, 2003 | 12:51 PM
ttt
LJS
Oct 3, 2017 01:14 PM
nabin
Jun 13, 2007 11:24 PM
crx-t
Aug 1, 2004 08:04 AM
Knightmare69
Sep 27, 2003 09:41 AM
