Change the fuel Filter
Old Aug 25, 2001 | 01:19 PM
ArchAngel Sabastian's Avatar
New User
Default Change the fuel Filter
how do i relieve the fuel pressure? anybody done this one before?
Old Aug 26, 2001 | 01:35 AM
Big James's Avatar
New User
Default Re: Change the fuel Filter (Sabastian)
Remove the gas cap.
Old Aug 26, 2001 | 04:59 AM
New User
Default Re: Change the fuel Filter (Big James)
lol... thats it i thought you had to do a bunch of other stuff.
is that all you have to do before you take out the old filter and put the new one in?
Old Aug 26, 2001 | 07:02 AM
SOHCArchangel's Avatar
there is a lil screw on the fuel rail u loosen too
Old Aug 26, 2001 | 07:05 AM
Low_bias's Avatar
No. that's no it. Sometimes there will be a little Schrader valve or something to push in...Not sure on Accord 'cause I haven't changed my filter yet.
Anyway, a liquid isn't compressible. Unless there is air in your fuel lines the gas will just trickle out when you crack the bolts open a bit. Where safety goggles and remove the filter slowly and it'll be OK.
Old Aug 26, 2001 | 07:18 AM
Big James's Avatar
New User
That is pretty much it. It is really simple to do if you can reach it. Use a flare nut wrench to avoid stripping the bolts.
Old Aug 26, 2001 | 03:50 PM
New User
yup i bought a 3pc set of those wrenches today at work. a mechanic came in and was changing the same thing on a 95.
thanks for the tip.
Old Aug 26, 2001 | 04:42 PM
New User
god damn... i cant get either of those bolts on the top and bottom of the filter to loosen up
any suggestion's? i dunno what else to try.
Old Aug 27, 2001 | 01:15 AM
Big James's Avatar
New User
Oh, I should have mentioned, they are the tightest bolts on a Honda! :D All i can suggest is a lot of muscle work. That is the only way to do it. They are a bitch.
Old Aug 27, 2001 | 02:37 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:18 AM 11/16/2006
Old Aug 27, 2001 | 03:51 PM
Default Re: Change the fuel Filter (schlit)
this is a good time to get an in-line fuel filter :D, something i should have done a long time ago
Old Aug 27, 2001 | 04:25 PM
New User
Default Re: Change the fuel Filter (SOHCkordVTEC)
..? not familar with that..
Old Aug 28, 2001 | 12:37 PM
briq4's Avatar
I think the manual actually says to take out the fuel pump fuse and then crank the engine to get rid of the pressure... I did that and when I took off the banjo bolt, not all that much fuel spilled, just have a towel tucked below the filter. Also I have no idea why but it was a MAJOR pain to get it back together again. They really could have put it somewhere better than in the engine compartment plus I was a little paranoid for a while thinking what if it leaks!? The heat from the engine might make the car blow up. But I'm still here (knock on wood) Just be careful and you'll be just fine. Oh and they are right that bolt is on VERY tight!
Old Aug 29, 2001 | 08:16 AM
emay1993's Avatar
New User
Default Re: Change the fuel Filter (briq4)
What is an inline fuel filter?
Old Aug 29, 2001 | 08:32 AM
Big James's Avatar
New User
Default Re: Change the fuel Filter (emay1993)
an insline fuel filter is exactly what the name inplies. A filter that goes inline of your fuel lines. It is a replacement for your stock fuel filter, and usually a higher flowing filter.
Old Aug 30, 2001 | 10:56 PM
5gen-hybrid's Avatar
New User
[QUOTE]I think the manual actually says to take out the fuel pump fuse and then crank the engine to get rid of the pressure...
you should do this because the fuel will still be under pressure if you don't. Then it makes a big mess when you loosen the banjo nut
Old Aug 31, 2001 | 06:13 AM
CardDealer's Avatar
Banned
Default Re: Change the fuel Filter (5gen-hybrid)
Modified by CardDealer at 4:19 AM 11/16/2006
Old Sep 1, 2001 | 06:10 AM
fixhondas's Avatar
Just break the damn bolts loose on the filter- you will get a little fuel spray- who cares? You are going to get fuel everywhere when the lines come out anyway. Use a honda filter- cheap ones dont have the filter capacity of the honda piece. OH yeah, take the gas cap off for a few seconds to relieve tha tank pressure- or fuel will constantly come out of the line when you disconnect the filter. I also find it helpfule to smoke a cigarette while doing this-haha.
Old Sep 20, 2001 | 10:00 AM
jsp304's Avatar
New User
I was looking to change my fuel filter. Have you done this before? If so would it be an easy job to do, or should it be done professionally? John
Old Sep 20, 2001 | 10:49 AM
New User
Default Re: Change the fuel Filter (jsp304)
well i ended up having a shop do it 20bux i would have spent more than that on tools to do it myself.
i also know the shop owner so that helped. the bolts are a pain in the *** to get off you will proly need
a set of metric flare nut wrenches and some crow foot wrenches i believe both bolts are 17mm
Old Sep 20, 2001 | 01:42 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:20 AM 11/16/2006
supamike3232
Oct 18, 2007 08:24 AM
STLblackcivic
Mar 26, 2007 03:12 PM
TMC_EF
Mar 22, 2007 01:07 PM
turboME
23
Jul 27, 2005 08:24 PM
handa
Apr 3, 2005 03:27 PM
