Help....how do I adjust the lights on my 03 Civic coupe
Old Sep 26, 2003 | 12:35 PM
03cvc's Avatar
Default Help....how do I adjust the lights on my 03 Civic coupe
I got an HID kit from JApan and I'm gonna post pics but they are aimed too high..please let me know how to aim them. I didn't get a manual with my car and already tried search. Pics coming as soon as I get them adjusted...
Old Sep 26, 2003 | 02:05 PM
EP3CivGrl's Avatar
Default Re: Help....how do I adjust the lights on my 03 Civic coupe (03cvc)
To be honest, I never looked at the headlight assembly. Try looking to see if there is a level on the headlights. If not, then youll probably have loosen the bolts and just adjust them that way. Cant wait to see those pics! How much was the kit and where did you get it?
Old Sep 26, 2003 | 04:44 PM
nein's Avatar
u are asking in the wrong place. ep3 is not your civic coupe
Old Sep 27, 2003 | 06:27 AM
CHILIBEANZ's Avatar
o3cvc- 1.look behind the headlight itself, there should be what looks like a small gear behind it. 2.use a phillips screwdriver(it's a tight fit) and put it between the gear teeth. 3.if u are facing the car, twist to the right and this will lower the beam(vice versa for up). u cant adjust sideways just up and down. i had the same problem with my rsx. btw have your car face a level wall with the lights on so u can see how much adjustment is needed. mike
Old Sep 27, 2003 | 07:33 AM
civicvtec1ps's Avatar
Default Re: (p220)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p220 &raquo;</TD></TR><TR><TD CLASS="quote">o3cvc- 1.look behind the headlight itself, there should be what looks like a small gear behind it. 2.use a phillips screwdriver(it's a tight fit) and put it between the gear teeth. 3.if u are facing the car, twist to the right and this will lower the beam(vice versa for up). u cant adjust sideways just up and down. i had the same problem with my rsx. btw have your car face a level wall with the lights on so u can see how much adjustment is needed. mike</TD></TR></TABLE>
good post
by the way. you might want to check out http://www.2k1civic.com
paolo2k2
Aug 29, 2007 08:10 AM
egproject
Sep 3, 2003 10:12 PM
