what happens when you do this
i want to put jdm b16 pistons in LS but i scared of detonation..what happens if ur pistons hit the valves? my jdn b16 pistons will be on LS rods. would i be better off using gsr pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote">.what happens if ur pistons hit the valves? </TD></TR></TABLE>
very bad things.
very bad things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">
very bad things.</TD></TR></TABLE> like ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">put the b16 pistons in, you'll be ok. get it tunned though</TD></TR></TABLE> people say tune, but how would i tune it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote"> like ?</TD></TR></TABLE>
you want a picture? I think I still have the valves laying around here somewhere...
This is what happened to my motor... There wasn't a piston to valve issue, but one of the valves did break off and rattle aroud for about 10 seconds... Regardless... Result is the same...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92CIVICCX »</TD></TR><TR><TD CLASS="quote">Is there any other inexspensive way of tuning motor after piston install</TD></TR></TABLE>
what? I don't understand the ? do you mean is there a way to help insure against valve to piston contact? yes clay the motor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 »</TD></TR><TR><TD CLASS="quote">
what? I don't understand the ? do you mean is there a way to help insure against valve to piston contact? yes clay the motor... </TD></TR></TABLE>
yes... instead of having to buy an aftermarket tuning system. If that is what your asking
thats makes sense!!! but can you return pistions after theyhave been pressed. heres the deal i got jdm b16 pistons on the b16 rods. im going to put them onmy LS rods. that will cost 75 bucs , if i clay the motor and the results are bad, that another 75 bux 150. i know its notalot of money but hey thats 75 bux that could go to my gas tank,tires,shifter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote">thats makes sense!!! but can you return pistions after theyhave been pressed. heres the deal i got jdm b16 pistons on the b16 rods. im going to put them onmy LS rods. that will cost 75 bucs , if i clay the motor and the results are bad, that another 75 bux 150. i know its notalot of money but hey thats 75 bux that could go to my gas tank,tires,shifter</TD></TR></TABLE>
75 dollars for tire(S)?? what kind are you buying..? all seasons?
that's dumb- 75 you have to spend to get the rods/pistons together, IF things don't work out then it's 75 to take it apart?! OK I guess I'll buy that- but I'm thinking that 75 to remove pistons that won't work in your setup is a hell of a lot less expensive than a new head,valves, pistons, rods, block... well you get the idea! There is nothing more imortant the having a safe motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 »</TD></TR><TR><TD CLASS="quote">There is nothing more imortant the having a safe motor</TD></TR></TABLE>
Amen brother.
-sander
Amen brother.
-sander
this is ridiculous.... 1300+posts and you dont know what tuning is, or what would happen if valves hit your piston..were all your 1300 posts in cosmetic or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">this is ridiculous.... 1300+posts and you dont know what tuning is, or what would happen if valves hit your piston..were all your 1300 posts in cosmetic or something?
LMAO
</TD></TR></TABLE>LMAO
lunaticracer21
Mar 18, 2007 09:56 AM
