Goodridge SS brake line users
Old Sep 26, 2003 | 08:27 AM
EFSiR's Avatar
Default Goodridge SS brake line users
With your fronts, did you get a bracket to attach the brake line to the strut? Or is it a zip lock deal (as I have it now).
I didn't get mine and I'm trying to find something to hold the front line securly near the shock without rubbing on the strut.
Old Sep 26, 2003 | 08:58 AM
FourthGenHatch's Avatar
Default Re: Goodridge SS brake line users (EFSiR)
Yes, there was a plastic triangle on the line that bolts up to the strut.
Old Sep 26, 2003 | 09:06 AM
EFSiR's Avatar
Default Re: Goodridge SS brake line users (FourthGenHatch)
true, I have that as well but in the old rubber lines, there was a metal bracket in addition to the triagle.
If I recall correctly my buddies KYB's shocks came with spare brackets to hold the lines in. I'm wodering if I could purchase these some where...
Old Sep 26, 2003 | 10:10 AM
EL Vap133's Avatar
Hmm, I haven't even checked mine. I'll be doing my conversion soon...
Old Sep 26, 2003 | 12:32 PM
jc836's Avatar
The only way you get the stock bracket is to have stock shocks-or remove them from a set of shocks you are taking off the car. Most of us use the "tie-wrap" method of securing the lines to the shocks and it works fine. Just run the tie thru the plastic piece and around the shock body.
Old Sep 26, 2003 | 01:05 PM
b16_madman's Avatar
I know these are the Earl's kit, which came with metal brackets.
Mounted onto 86-89 accord shocks....see pic fer details....
Old Sep 26, 2003 | 06:37 PM
NCchris's Avatar
My goodridge lines came with the black plastic brackets that were self explanatory. The also had a piece of silicone tubing about an inch long on them to fit in the stock metal brackets that bolt to the bottom of the shock. The silicone tubing acts like a bushing to make the line same as stock diameter to fit the stock brackets.
HTH
chris
Tesla220
Suspension & Brakes
12
Jun 15, 2011 04:57 PM
Zion-I
Suspension & Brakes
Jan 19, 2006 06:32 PM
fireant
May 4, 2005 06:47 AM
Weston
22
Nov 19, 2004 07:42 PM
HondaIntegraLS
Jul 16, 2001 02:16 AM
