Plug wire keeps popping out! Please help
Old Sep 26, 2003 | 05:45 AM
ltho1998's Avatar
Default Plug wire keeps popping out! Please help
Alright, we put in my gf's ZC a few months back and has been running cherry since, until we discovered one of the plug wires were popped out. So we put it back in and a mile passes by and it pops out again. We've been continuing to just plug it back in and it just keeps popping out.
So, I checked for maybe a leaky spark plug, if thats even possible.. as good as can be. There is a slight amount of oil around the plug boot.. So i'm suspecting leaky or incorrectly seated plug hole/valve cover gasket. But would this be a cause?
Any other opinions?
Old Sep 26, 2003 | 06:57 AM
FourthGenHatch's Avatar
Default Re: Plug wire keeps popping out! Please help
There are spark plug seals on the top of the valve cover. Replacing those should get rid of your oil leak issues.
Also you might try clamping the spark plug wire down on the end so the metal part that grabs the top of the spark plug is tighter and it might hold better.
Old Sep 26, 2003 | 07:25 AM
GIAMotorSports's Avatar
Default Re: Plug wire keeps popping out! Please help (FourthGenHatch)
Get new set of plugs and wires and that should solve your problem
Old Sep 26, 2003 | 10:36 AM
manson's Avatar
Default Re: Plug wire keeps popping out! Please help (GIAMotorSports)
buy honda plug wires... they fit perfect.
Old Sep 26, 2003 | 01:15 PM
b16_madman's Avatar
Default Re: Plug wire keeps popping out! Please help (ltho1998)
my friends gsr-turbo was doing the same thing, but on the dist. cap.
We don't know why?
Zip ties solved his problem.
Old Sep 27, 2003 | 04:45 AM
NCchris's Avatar
Torque your plugs. Check PCV valve and related plumbing. Cyl/ring blow-by can cause positive pressure in the crankcase and under valve/camcover. This will force oil into the spark plug tube, lubricating the plug wire and possibly blowing off the wire. Changing the seals under the plug tubes will help a lot too. My HF motor did this!
HTH
chris
Old Sep 27, 2003 | 05:52 AM
CRneXt's Avatar
Default Re: Plug wire keeps popping out! Please help (mansonclubpuir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mansonclubpuir &raquo;</TD></TR><TR><TD CLASS="quote">buy honda plug wires... they fit perfect.</TD></TR></TABLE>
ED ZACHARY. I concur... I just want to know what to use when running like a 8mm or bigger...
Thanks,
Scott
Cmanning816
Apr 23, 2014 10:57 PM
crashsvg
Dec 1, 2008 05:51 PM
exile29
Oct 6, 2006 08:53 PM
lethalgsr32
Dec 31, 2005 03:50 PM
WickidSi
Feb 1, 2003 06:26 PM
