2.0 DC2 Dyno results
Old Sep 26, 2003 | 12:51 AM
JDiMageDC2's Avatar
Default 2.0 DC2 Dyno results
Just finished my build around a month ago and took my GSR to Houston last week to have a Hondata added and dyno tune it. Graph is attached. I am really dissapointed with the all motor numbers, I was hoping for 200+ hp and 150+tq. We were planning on doing some more dyno time this weekend and playing with the ignition and timing maps with the hondata but i got spray happy this past weekend and tore **** up. The fully built motor loved the botttle though. The plots show it N/A then with 150 shot, then a 200 shot. Im pulling the head this weekend because Im pretty sure I burnt the piston rings or possibly bent valves in the #1 chamber. No more nitrous, Im somewhat determined to get it how i want it N/A and Im also tempted to drop the compression and boost it. Im listing the major mods to the motor below, a full descrip may come later. Any constructive input on the n/a numbers would be appreciated.It just seemed to fall off at 7-7500k when i wanna take it to 9500rpm. Dropped when it went further. Wideband 02 used to tune as well of course, numbers were adjusted appropriately. Jason at Autologic did the tuning. Powerband was able to be smoothed out alot compared to before. But damn it was weak, whats goin on here guys. Compression numbers were 260-270 across the board and leakdown numbers were cyl1, 29, cyl2, 30, cyl3, 18, cyl4, 33. Trash talkers SHattup, Im already pissed enough. Just wanted to share. Later
B18C1
Golden Eagle Sleeved 85mm
Balanced and Blueprinted
Stage 3 port and polished head
skunk2 valvetrain and Skunk2 stage 2 cams
JE pistons 12:1 CR
Eagle Rods
370cc injectors
65mm TB and Skunk2 IM
complete motor and tranny cryotreated
Hondata S200
Old Sep 26, 2003 | 01:01 AM
K20EG's Avatar
those are some cool numbers
Old Sep 26, 2003 | 01:18 AM
advanracing62's Avatar
Default Re: (K20EG)
I'd be a little disappointed with the numbers as well. The NA number seems low, is that after the bottle? ie- after damage was done? The motor should be really strong, but on the bottle it's a killer... close to 300whp, not bad- though I am diametrically opposed to FI
Old Sep 26, 2003 | 01:30 AM
JDiMageDC2's Avatar
Default Re: (advanracing62)
No, those N/A numbers are with no damage.
Old Sep 26, 2003 | 04:12 AM
GOLDBERG's Avatar
Default Re: (GSRTUNR)
thas really ****** weird.... 164whp with all those mods very shitty tuning i guess
Old Sep 26, 2003 | 04:26 AM
Casey's Avatar
Default Re: (GOLDBERG)
i think you had a problem before the tuning. get those parts replaced and break it in properly, and 200/150 all motor is possible
Old Sep 26, 2003 | 05:00 AM
CHEETAH's Avatar
Default Re: 2.0 DC2 Dyno results (GSRTUNR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRTUNR &raquo;</TD></TR><TR><TD CLASS="quote"> leakdown numbers were cyl1, 29, cyl2, 30, cyl3, 18, cyl4, 33. Trash talkers SHattup, Im already pissed enough. Just wanted to share. Later
leakdown numbers are your problem. Where was most of your leak ?
Greg
Old Sep 26, 2003 | 05:43 AM
MEANB18's Avatar
Default Re: 2.0 DC2 Dyno results (CHEETAH)
haha I'm still giggling like a little school boy about the spike in Horsepower when you hit the funny button. That's impressive, must be one hell of a ride... Just imagine if it was completely tuned making 200+ horsepower BEFORE you run the nitrous, 350? 400? Can't wait to see it done perfect!
Old Sep 26, 2003 | 06:39 AM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">
Greg</TD></TR></TABLE>Also was leakdown before or after the dyno pulls?
Old Sep 26, 2003 | 08:25 AM
Rob Dizzle's Avatar
Default Re: 2.0 DC2 Dyno results (fkned)
who built the motor?
Old Sep 26, 2003 | 09:06 AM
GokuSSJ4's Avatar
Default Re: 2.0 DC2 Dyno results (Bob-DC2)
very low # s on the N/A set up . you should at least had over 200whp .
also i thought 12.1CR was to high to even run nitrous ???
Old Sep 26, 2003 | 09:56 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: 2.0 DC2 Dyno results (Spoon1)
Motor could be choked, too. He didn`t mention what his header/exg setup was.
Old Sep 26, 2003 | 12:40 PM
ispkarl's Avatar
piston size??
headder??
exaust???
Old Sep 26, 2003 | 01:34 PM
WOTTEG's Avatar
Default Re: 2.0 DC2 Dyno results (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">He didn`t mention what his header/exg setup was.</TD></TR></TABLE>
My thoughts also.
This could be the problem too:
Stage 3 port and polished head.
An inexperience head porter can create inefficiency. Especially if the ports are opened too much.
Old Sep 26, 2003 | 01:37 PM
JDiMageDC2's Avatar
Default Re: 2.0 DC2 Dyno results (WOTTEG)
85mm ,12:1 CR JE PISTONS, JDM ITR 4-1 header, Skunk2 catback.
The Motor was built by POLK PERFORMANCE.
Old Sep 26, 2003 | 02:27 PM
vtecvoodoo's Avatar
Future Texas Boy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRTUNR &raquo;</TD></TR><TR><TD CLASS="quote"> JDM ITR 4-1 header</TD></TR></TABLE>
problem #1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRTUNR &raquo;</TD></TR><TR><TD CLASS="quote"> Skunk2 catback.
problem #2.
Old Sep 26, 2003 | 02:33 PM
Rob Dizzle's Avatar
problem #1.jdm 4-1
problem #2.skunk2 exh</TD></TR></TABLE>
nah, we just had a 1.8l with cp pistons, ef-1 m22s, head work and itr intake manifold hit 198whp with mild tuning. he had dc header, carsound cat and apexi ws exhaust.
if a 1.8 can make that much with that header, im sure a built 2.0 can make that much
i bet there is something wrong with this guys setup. i havent really heard of polk, did you call them and tell them a stock itr motor with the same header and hondata would make more power?
Old Sep 26, 2003 | 02:37 PM
StinkyTofu's Avatar
problem #1.
problem #2.</TD></TR></TABLE>
I agree, but even with those bottlenecks, he should be well over 160.
vtecvoodoo's Avatar
Future Texas Boy
Yah, but this is a 2 liter. It needs to breath. He obvioulsy has quite a few problems.
Old Sep 26, 2003 | 02:39 PM
GSRswapandslow
Guest
Posts: n/a
i've got a friend that just layed down money to get his engine built for Nitrous too
but i really hope he puts down more than that...
i mean, on bottle...it looks good for the 150 shot...but the 200 is a little low...and the n/a is horribly low...
Old Sep 26, 2003 | 03:54 PM
Retired's Avatar
WEST COAST
Im thinking this the tuner compisated to much timing for the Nitrous! What we do with a nitrous car on hondata etc. We tune the car at is peak potenial using the Hondata or what ever fuel managment first. Then we use a msd digital 6 plus wired to the nitrous silinoid, once the nitrous silinoid is enganed then the digital 6 plus will automaticaly retard the timing this way you will get no loss of timing in your N/A form. If you have any more question feel free to give me a PM or a call.
Good Luck
Old Sep 26, 2003 | 04:09 PM
TREVER's Avatar
Default Re: 2.0 DC2 Dyno results (SPARK RACING INC.)
there's my setup from last year to compare fairly similar.
Old Sep 27, 2003 | 06:16 PM
asubennett's Avatar
Default Re: 2.0 DC2 Dyno results (TREVER)
370 injectors on a 85 mm bore is limiting, header is also limiting but not damning. And I agree with the timing issue, perhaps the tuner left it at 12-14 degress for the nitrous pulls when you did the all motor pulls. 65mm throttle bodya bit small as well for such big bore and port work. I would go with a 70mm and have it port matched to the im.
Old Sep 28, 2003 | 11:10 AM
specie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER &raquo;</TD></TR><TR><TD CLASS="quote">
there's my setup from last year to compare fairly similar. </TD></TR></TABLE>
That's a badass graph. A 100 shot makes 106whp. Can't wait until I get started on my buildup.
Back to the post:
What kind of dyno was it on? Could be a mustang dyno that gives lower hp readings. If it's a dynojet, that is low. I'd think that even a non-tune more would make more power, but it could be running rich, or retarded timing. But you got some ***** throwing on a 200shot. Good luck with the project.
Old Sep 28, 2003 | 03:15 PM
TREVER's Avatar
Default Re: 2.0 DC2 Dyno results (specie)
thanks specie.
I think the key to get a nos set up running right is to dial in the n/a tuning first. I would of not put a 200 shot on a engine thats running badly the nos will only compound the problem. I used no timing retard either. I tuned the timing on pump gas. Then I put in 103 octane on the nos, worked great for me.
