Clutchnet clutch bad after 15k?
Old Sep 25, 2003 | 08:09 PM
mattmw88's Avatar
Default Clutchnet clutch bad after 15k?
I was driving my car and the clutch pedal went soft. I've been told by multiple shops that something inside my tranny is bad, either the pressure plate or the clutch itself. Funny thing is that I got it because of some special that was advertised with H-T. Sux to have my luck... or is this normal?
Old Sep 25, 2003 | 08:27 PM
del_parker's Avatar
Default Re: Clutchnet clutch bad after 15k? (mattmw88)
can you describe in better detail what's wrong?
Old Sep 25, 2003 | 08:42 PM
rjr162's Avatar
Default Re: Clutchnet clutch bad after 15k? (del_parker)
I don't know about the 4th gen's, but I know the 5th gens and I think accords are prone to the master cylinder developing leaks. Check the area around it to make sure it's not leaking. Alot of times all it takes is the extra pressure from a newer/upgraded pressure plate to really bring the leaks out
redline7
Feb 23, 2008 08:53 PM
94accord718
Sep 10, 2007 01:22 PM
ash.zero
Nov 9, 2005 02:05 PM
HiAssHell
Nov 5, 2005 05:04 PM
