CX injector flow rate???
Old Sep 25, 2003 | 08:02 PM
flat-blk-HB's Avatar
Default CX injector flow rate???
I am tring to run my LS vtec with my stock injectors..(cx) will it work?
The motor is idling at like 200-300 RPM's and I thought this might be a reason?
Yes the Thorttle Cable is tight
Old Sep 25, 2003 | 08:05 PM
aw1234dude's Avatar
Default Re: CX injector flow rate??? (flat-blk-HB)
Dont all b and d series injectors flow the same 240cc. Im pretty sure i read that they do.
Old Sep 25, 2003 | 08:07 PM
Default Re: CX injector flow rate??? (aw1234dude)
yeah I just read that too...
I wonder what it could be....
Old Sep 25, 2003 | 08:17 PM
dantastic's Avatar
200-300rpm? sounds like the cam timing is off a tooth or 2
Old Sep 25, 2003 | 08:20 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (dantastic)
if you just swapped, you may need to adjust the idle screw on the TB.
Old Sep 25, 2003 | 08:36 PM
Default Re: (Emerika)
Yeah I just swapped TB too..I am going back to the B16A tomorrow.....I put on a Bored Ls but I think that might be the problem...It ran fine before
Old Sep 25, 2003 | 08:37 PM
Dancing is Forbidden's Avatar
Default Re: (flat-blk-HB)
cx injectors are smaller than 240cc.
Old Sep 25, 2003 | 08:41 PM
Default Re: (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">cx injectors are smaller than 240cc. </TD></TR></TABLE>
Are you for sure???
Old Sep 25, 2003 | 08:43 PM
almost 100% This is why Hasport and many other places recommend using dx injectors or something else other than cx/vx injectors.
Old Sep 25, 2003 | 08:45 PM
Intresting, I will have to look into this.......
Old Nov 12, 2003 | 06:10 PM
digitalcongo's Avatar
i need the answer too...for my '94 vx...
i think they are the same injectors as the cx...
the closest list i found here...
ACCEL Fuel Injetors PDF
i'm guessing they are either 180cc or 235cc
I need to replace an injector...and i cant until i know the damn flow...
and find a seller...
uhg...
Old Nov 13, 2003 | 10:03 AM
BatuKing's Avatar
No ALL D series and B Series injectors are the same.. This is a proven fact.. you can do a search and you will find alot of discussions regarding this.
Old Nov 13, 2003 | 10:07 AM
BatuKing's Avatar
Default Re: (digitalcongo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalcongo &raquo;</TD></TR><TR><TD CLASS="quote">i need the answer too...for my '94 vx...
uhg...</TD></TR></TABLE>
IF you need OBD-1 or OBD-2 Stock injectors let me know I have a set for sale for $45 shipped.
If you click on that chart you will see the actual flow rate of the injector, but at what the ecu pulses it at.. so even though your injector is capable of 240cc the duty cycle varies on the ecu your running..
I have done some research with reading and actual hands on also called RC engineering and they also agreed they are all at 240cc at max duty cycle
Tad
Northern California (Sales)
Mar 13, 2006 05:44 PM
hatchfreak92
Mar 28, 2005 08:45 PM
flat-blk-HB
Oct 31, 2004 02:54 PM
Tad
24
Aug 13, 2004 03:54 PM
Trooper
May 2, 2003 09:56 AM
