Suspension Problem Help!! ASAP
Old Sep 25, 2003 | 05:10 PM
hYpE-R-29's Avatar
Default Suspension Problem Help!! ASAP
I recently found out that I needed new control arms and knuckle arms on the right side of my my car(Right front, Right Rear). After install my right side seems alot higher than my left. I have H&R Sport springs installed and my whole right side is about 1/2 higher than the left. The arms we're installed using jack stands as supports, should I have used a alignment rack to support all wheels???..need help asap....
Modified by hYpE-R-29 at 5:52 AM 9/26/2003
Old Sep 25, 2003 | 05:15 PM
hYpE-R-29's Avatar
Default Re: Suspension Problem Help!! ASAP (hYpE-R-29)
forgot to mention.....Do u think its normal??, because I heard it can settle down with just driving.....any help is great
Old Sep 25, 2003 | 06:15 PM
hYpE-R-29's Avatar
help!! ttt
Old Sep 25, 2003 | 07:42 PM
hYpE-R-29's Avatar
someone??
Old Sep 26, 2003 | 07:21 AM
typer_801's Avatar
Drive it and see if it comes down. My car generally sit 1/2" higher after screwing around with it (having it jacked up). Then it settles ones you drive it again and is at the normal ride height.
Old Sep 28, 2003 | 06:48 PM
hYpE-R-29's Avatar
Default Re: Suspension Problem Help!! ASAP (typer_801)
ttt..
iHATEspeedbumps.
Jul 6, 2005 03:41 PM
orgear
May 9, 2005 12:19 PM
hYpE-R-29
Sep 25, 2003 08:47 PM
austrian type-R
Jul 5, 2003 10:15 AM
