gsr block with crx harness?
Old Sep 25, 2003 | 02:39 PM
nevin's Avatar
Default gsr block with crx harness?
I have a obd0 b18a in my crx. I can pick up a b18c short block and I was wondering if I got a obd0 b16 head to go on it would i need the gsr wiring harness for the motor to work or could I use my existing harness?
Old Sep 25, 2003 | 03:21 PM
APEX CRX's Avatar
if you have an Si you can use your existing harness and add 3 wires only
Old Sep 25, 2003 | 08:13 PM
nevin's Avatar
So if I use a obd1 gsr block with an obd0 b16a head/distributor I can use my existing obd0 crx harness and chipped obd0 ecu to tune the fuel? Just making sure this will work before I try it.
Old Sep 25, 2003 | 08:22 PM
carrcarr's Avatar
Default Re: (nevin)
if you have Vtec and multiport fuel injection already, you can do it
Old Sep 26, 2003 | 12:18 AM
nevin's Avatar
i was planning on using a vafc for the vtec and yes hf is multipoint
jordy75
Aug 9, 2010 02:51 PM
crxowner
Oct 24, 2006 05:51 PM
spinney
Jul 28, 2005 12:50 PM
crazyb16crx
Jul 18, 2004 09:43 AM
nevin
Sep 25, 2003 02:46 PM
