DX header Vs Si header
Old Sep 25, 2003 | 01:31 PM
Todd00's Avatar
I said I don't want a title!
Default DX header Vs Si header
is there any difference between the 88-91 Dx header (D15b2) vs the 88-91 Si header (D16a6)? Will an a6 aftermarket header work on a b2? I assume it will bolt right on, but the attachment to the exhaust look sa bit different.
Old Sep 25, 2003 | 07:58 PM
redzcstandardhatch's Avatar
something different
Default Re: DX header Vs Si header (Todd00)
shouldnt be any difference from the factory, only if an exhaust shop had modified it would it not work. the head casting numbers are the same, everything bolts up.
Old Sep 25, 2003 | 08:02 PM
carrcarr's Avatar
Default Re: DX header Vs Si header (redzcstandardhatch)
D to D works, i would say the only posible difference is the length...you might want to check that out........but why would you swap stock header for stock header?
Old Sep 25, 2003 | 08:42 PM
Vinceg99's Avatar
Default Re: DX header Vs Si header (carrcarr)
I think there is a difference between the pipes that go from the exhaust manifold to the cat. But otherwise I had an stock Si exahust manifold right next to a stock DX manifold and they were identical.
Old Sep 26, 2003 | 11:57 AM
Todd00's Avatar
Default Re: DX header Vs Si header (Vinceg99)
I just bought a 91 Dx hatch and the header goes into a funky jog pipe that goes into a converter. I didn't think the jog pipe was oem, but it is a oem looking piece actually.
I was going to throw a DC 4-2-1 on the Dx motor (that I had on my Si) just for the heck of it, and I was hoping everything was similar.
Old Sep 26, 2003 | 12:01 PM
Hybrid Invasion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a 91 Dx hatch and the header goes into a funky jog pipe that goes into a converter. I didn't think the jog pipe was oem, but it is a oem looking piece actually.
I was going to throw a DC 4-2-1 on the Dx motor (that I had on my Si) just for the heck of it, and I was hoping everything was similar.</TD></TR></TABLE>I wouldn't bother doing anything to a DX motor at all. It's DPFI, so you won't notice hardly any difference whatsoever, as i'm sure a lot of other people on h-t, as well as other people will tell you. It's a waste of money. You could do a MPFI conversion on it, but that is a waste of money too IMO.
Old Sep 26, 2003 | 12:06 PM
Todd00's Avatar
Default Re: DX header Vs Si header (Hybrid Invasion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Invasion &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't bother doing anything to a DX motor at all. It's DPFI, so you won't notice hardly any difference whatsoever, as i'm sure a lot of other people on h-t, as well as other people will tell you. It's a waste of money. You could do a MPFI conversion on it, but that is a waste of money too IMO. </TD></TR></TABLE>
I have 90% of the parts to do the mpfi conversion, so that's the plan. And I have the header in my basement, so I might as well. It's just a winter beater so I want to keep the upgrades cheap and try to make the car a little more fun.
Old Sep 26, 2003 | 02:04 PM
I have 90% of the parts to do the mpfi conversion, so that's the plan. And I have the header in my basement, so I might as well. It's just a winter beater so I want to keep the upgrades cheap and try to make the car a little more fun.</TD></TR></TABLE>well if you already were planning on doing the MPFI swap, you might as well go ahead and do it till you can do a motor swap. I was once in your shoes; I waited almost 4 years after I got my car before I even did anything to it, then I saved up and got a b16 swap and did it myself...cheers to working with what you have.
bruleke
11
Sep 11, 2014 05:16 AM
HondaHeddie
Nov 20, 2006 08:08 AM
dmxsoulja3
Nov 11, 2004 08:28 AM
RACING INTEGRATION
Mar 15, 2003 08:09 PM
b16awarrior
Oct 15, 2002 05:06 PM
