ZC head + LS block?
I actualy know that you can’t mix the b and d series parts.But since the valve covers look so similar i have to ask,is it possible to put a ZC head on an b18a or b18b block?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GIAMotorSports »</TD></TR><TR><TD CLASS="quote">No the zc head and the zc block only mate to each other </TD></TR></TABLE>
This is only true when it comes to the DOHC ZC. With the SOHC ZC you can use the SOHC ZC head on the D-series (a6,z6,and y8) you can also use any of those heads on the ZC block.
can you mount a dohc zc head onto a d16a1 block since they are so similar? zc has bigger cams, so this would be cool
zc code is d16a8/9
89 teggie d16a1
just a question ive been wondering for awhile
zc code is d16a8/9
89 teggie d16a1
why you throwin hammers like a mad man it's a legit question, maybe not b series and d series, but why wont a zc head fit on a d16a1?
any dohc zc head will fit on a d16a1 the seciound gen zc head will requiri adj cam geras ther is a timming difference
the dohc head will also fit with some mods to an EW block
and do you have a d16a1 in you 2nd gen or is it a 1G
