Those with LS/VTEC in a G2 teg....What headers do you use??
Old Aug 24, 2001 | 06:34 PM
93B18's Avatar
Default Those with LS/VTEC in a G2 teg....What headers do you use??
I just had mine done and I wanted to use DC 4-2-1 headers made for a 93 GS/GSR but the second pipe where it splits into 2 won't clear the oil pan. I have a 93 LS and I thought it would fit but it hits the oil pan. I'm running a B18A bottom with B17 (same as B16) oil pan with a B17 head. I am now temporarily running my stock manifold off of my old 93 B18A motor and it works fine but the side of the manifold butts up right again the oil pan. Any suggestions? Should the DC work?? What headers are you guys using with your LSVTEC? Thanks in advance for the info fellas. Much obliged.
Old Aug 24, 2001 | 07:15 PM
TypeC's Avatar
Default Re: Those with LS/VTEC in a G2 teg....What headers do you use?? (93B18)
I had a LSVTEC in a '93 integra. I was using aftermarket B18a header and the stock B18a oil pan. I think the b17a oil pan is what is causing things not to fit. I'd put the b18a one back on. HTH, -C
jessedm
Nov 19, 2010 11:01 PM
jdm93integrals
Jan 29, 2009 07:14 PM
BoSox46GSr
Dec 25, 2008 05:20 PM
ITRiWISH
Jul 13, 2008 07:19 PM
GTWITIT
Feb 20, 2006 05:44 PM
