K20a2 swap or K20a3 with Type S Head swap?
Old Sep 24, 2003 | 10:10 PM
Kirei's Avatar
Default K20a2 swap or K20a3 with Type S Head swap?
I've never been a fan of F/I but after seeing a few turbocharged EPs, its got me contemplating over it. Idealy, I would like to swap a k20a2 and charge it because I would start off with a better motor, but what i've heard is that its not good to charge it because it already runs at a high 11:1 compression. What I've seen a lot of people do is swap the type s head and use the k20a3 block since it runs at a lower compression. It would be cheaper for the k20a3 + type s head swap and then charging it but money really isnt an issue. Anybody with a turbocharged type s or ep or know your stuff please speak your mind =P
Old Sep 25, 2003 | 10:29 PM
andyep3's Avatar
Default Re: K20a2 swap or K20a3 with Type S Head swap? (Kirei)
It seems the general consensus is if you're going turbo, either stick with the
a3, build it and boost the hell out of it or get a K24 and boost the hell out of
that (possibly with the A2 head). If you're going NA, get the K20A/A2, new cams,
new valve train, etc. and get some sick NA numbers going (plus good gas
mileage ).
That's not to say a boosted A2 isn't a very respectable engine - the RSX guys
are obviously getting a lot out of their stage 2+ turbo kits, but that involves new
pistons and other internals. Heck, the 260whp that the turbo'd A3 guys are getting
is nothing to be scoffed at. Add a limited slip, some slicks and other get-the-power-to-the-ground mods
and we're going to see some very fast Si's/base RSX's.
Old Sep 27, 2003 | 11:59 AM
brian g's Avatar
Default Re: K20a2 swap or K20a3 with Type S Head swap? (andyep3)
The Si bottom end is weak compared to the Type S or any of the K24 bottom ends. Because the ECU limits you to moderately low boost, the Type S engine works nicely.
I suggest you do the head swap and use the savings to buy the K24 bottom end.
Leave the stock tranny in but get an LSD. The 5 speed tranny is not a hinderance to perormance as much as the lack of an LSD is.
brian g
Old Feb 6, 2004 | 06:38 PM
iRRATiONAL's Avatar
where is the best place tp pick up a k20a2 with 6 speed tranny and ecu at a decent price?
Nate13
15
Dec 16, 2009 10:50 AM
projectd815
12
Aug 2, 2009 03:12 PM
NOTyard
Honda Civic (2001 - 2005)
Dec 26, 2006 03:37 PM
02NJHondaep3
Feb 22, 2004 10:52 AM
