Best anti seize compound for Tein HA's?
Old Sep 24, 2003 | 08:00 PM
is3oo's Avatar
Default Best anti seize compound for Tein HA's?
I just purchased a brand new set of Tein HA's and was wondering what the best anti seize compound is to apply on my coilovers. Also I was wondering if the Tein HA's are made of steel or aluminum? Most likely steel, but just making sure. Thanks.
Old Sep 24, 2003 | 08:02 PM
sackdz's Avatar
Default Re: Best anti seize compound for Tein HA's? (Type-Rizzle)
Steel. Use "regular" antiseize and clean/spray them with penetrating oil periodically.
Old Sep 24, 2003 | 10:05 PM
is3oo's Avatar
Default Re: Best anti seize compound for Tein HA's? (sackdz)
Where can you purchase some anti seize? Any auto store?
Old Sep 24, 2003 | 10:06 PM
is3oo's Avatar
And what areas should I apply the compound to?
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">Steel. Use "regular" antiseize and clean/spray them with penetrating oil periodically. </TD></TR></TABLE>
ding ding!
and if you live in salty lands, you may want to consider the RA's, which are the aluminum counterpart.... which would sitll probably seize....just wont rust
Old Sep 24, 2003 | 10:07 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Rizzle &raquo;</TD></TR><TR><TD CLASS="quote">And what areas should I apply the compound to?</TD></TR></TABLE>
any autostore.
and between the perch and the threading.
i'd even generously put it on the bottom portion of the spring itself.
Old Sep 25, 2003 | 06:22 AM
Nick248's Avatar
Default Re: Best anti seize compound for Tein HA's? (Soup ****)
Apply antiseize to only the threaded portion that you will be using. Antiseize is really gooey so you don't want every little pebble sticking to it.
After installed, spray the whole assembly down with WD40. Re-apply WD40 every 2-3 months. If the car doesn't see rain, then every 6 months is fine. I've had my set for over 2 years with no rust problems whatsoever. Plus I live in Northern NJ.
-Nick
Old Sep 25, 2003 | 06:39 AM
Flux's Avatar
Default Re: Best anti seize compound for Tein HA's? (Nick248)
Is there something that can be used that does not attract all the grime, sand, dirt and pebbles on the road?
Old Sep 25, 2003 | 07:32 AM
BakedCookies's Avatar
Default Re: Best anti seize compound for Tein HA's? (Flux)
my tein flex coils came with a can of antirust spray, i coated the threaded areas and the perch/bottom of spring.. should i be using something else?
Old Sep 25, 2003 | 08:45 PM
DB2-R81's Avatar
25 Year Member
Default Re: Best anti seize compound for Tein HA's? (BakedCookies)
Get a bread loaf baking pan, melt some canning wax in the pan and roll them in. Dirt will not stick to the dampers and the wax will protect the dampers from H2O.
Old Sep 25, 2003 | 08:50 PM
jansenrw's Avatar
i put fish oil on mine.. yes dirt will stick but its easy to remove with wd40!!
Old Sep 25, 2003 | 08:58 PM
Blazin ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick248 &raquo;</TD></TR><TR><TD CLASS="quote">Apply antiseize to only the threaded portion that you will be using. Antiseize is really gooey so you don't want every little pebble sticking to it.
-Nick</TD></TR></TABLE>
Words of Wisdom and Experience!
Little rusting on my HA's, but no major problems with the Teins. Plus, I spray mines annually.
Old Sep 26, 2003 | 02:13 AM
is3oo's Avatar
Default Re: Best anti seize compound for Tein HA's? (Blazin ITR)
How long does the anti seize last? So there is no need to re-apply? Just spray it down w/ WD40 in the future?
Old Sep 26, 2003 | 10:56 AM
DarthLuder's Avatar
New User
should of got the flex, I heard its good for salty areas.
teg_dc2
Mar 11, 2008 01:47 PM
VTEC_PRODUCTION
Suspension & Brakes
Feb 6, 2008 01:15 PM
gooberwolf
Sep 24, 2005 07:28 PM
coolasice
Nov 14, 2003 11:43 PM
