CRX mini me swap. Help with injectors...??
Old Sep 24, 2003 | 07:47 PM
xmd's Avatar
xmd
Default CRX mini me swap. Help with injectors...??
Ok, So I've done my mini me swap with a d16y8 head on my D16a6 block. I'm using the y8 intake. I've spliced all of the odb1 plug connectors on the ecu.. so thats pinned out. now I've got the clips from the odb1 harness for the injectors but how do i wire them up.
I've tried just solidering them where the old clips were but this isnt working at all...
Do i replace more than just the clips to make the injectors work?
any help is appreciated...
http://131.103.202.145/minime.htm
thats how far i've gotten.
Old Sep 24, 2003 | 07:52 PM
USDM 4G VTEC's Avatar
Default Re: CRX mini me swap. Help with injectors...?? (xmd)
if u havent done all the MPFI wiring..... i recomend u do so asap
as far as the conector u need OBDO not the oBD1
Old Sep 24, 2003 | 08:37 PM
b18befhatch's Avatar
are you using a obd1 ecu, if so are you using the crx resistor box if so that is your problem you need to run the injectors straight to the computer
Old Sep 25, 2003 | 04:53 AM
xmd's Avatar
xmd
It's a si so its already mpfi. and I'm runnin a odb1 p28. and i know that my old odb0 injectors wont work. i was just wonderind whats the deal with the new injectors..
i cliped the old injector clips off and wired the new ones up. now one wire from the clip go's to the ecu... the other wire go's to the resistor box..
now i know i need to remove the resistor box.. its that second wire im confused about..
-x m d
Old Sep 25, 2003 | 05:29 AM
CimorelliCRX's Avatar
to use obd1 injectors you have to put hte new clips on. what i would do is run the si injectors iwth resister box and you will be fine.
Old Sep 25, 2003 | 05:42 AM
xmd's Avatar
xmd
unfortunatly i destroyed the old clips takin them off. and the rings on the old injectors are bad so i need to use the odb1's
so the injector clips just wire back into the old clips place... well... what about the resistor box... where do all those wires go? cause thats the other leg of the injector's
-x m d
MastaFlyMason
Sep 3, 2017 10:06 AM
88EFsedan2
Jan 13, 2012 02:57 PM
tyvtec23
Nov 11, 2011 05:37 PM
xmd
Sep 27, 2003 12:56 PM
markedOO1
Nov 26, 2001 07:50 AM
