obd1 and obd2 questions
Old Aug 24, 2001 | 03:48 PM
therealnapster's Avatar
New User
Default obd1 and obd2 questions
Can you use an obd2 distibutor with an obd1 ecu? I swapped heads on my 95' civic with the head and distributor from a 97' I'm getting engine codes 1 and 4 could this be my problem, thanks.
-Derek-
Old Aug 24, 2001 | 06:47 PM
BreakStuff's Avatar
New User
Default Re: obd1 and obd2 questions (sohckid)
How does the car run after the swap?
I can see it throwing a code 4, OBDI used a crank angle sensor located in the distributor assy, and OBDII used a sensor located near the crank pulley, I do not know what year the crank angle sensor was actually moved down "below" and replaced with the CYP sensor in the distributor.. but I do believe it was right around 97..
sikcrx80
May 1, 2023 05:16 PM
akinas-crx
Oct 28, 2011 06:00 PM
Rat_Bear
Jan 29, 2009 08:01 PM
sPaRk'iT
Aug 15, 2007 06:50 PM
therealnapster
Aug 24, 2001 04:13 PM
