DONT buy the Godspeed test pipe!!!!
Old Aug 24, 2001 | 03:34 PM
blktyper2001's Avatar
New User
Default DONT buy the Godspeed test pipe!!!!
Here is why:
1. The test pipe is too long so the exhaust is pushed out by about 1-2 inches.
Parts of the exhaust touch the bottom of the car. And godspeed says this is the
new improved design.
2. The the pipe that holds the O2 sensor is so high the O2 sensor can not sit
upright. The test pipe has to be tilted. This causes the the 02 sensor to be
stretched out so much, that is barely fit.
3. This is the worst part. The cat material broke and then broke into many small
piece. This caused my cel light to come on.
4. On the stock cat youcan see a foam like material around the cat. This absorbs
the shocks and bumps so your cat doesn't get damaged. The God speed pipe
doesn;t have it. The cat material just rattles around metal.
Save yourself headaches and just get a high flow cat. I finally got a carsound cat and it fit perfectly like the stock cat.
Old Aug 24, 2001 | 03:37 PM
Luke's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (blktyper2001)
What sort of gains have you got with it?
Old Aug 24, 2001 | 03:40 PM
Austin's Avatar
Did you speak with Dan about this prior to posting this?
Old Aug 24, 2001 | 03:43 PM
onyx00's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (luke)
I have one of Dan's earlier test pipes and have had no problems as of yet. My only problems were the following:
1.) Too long, but I was still able to get it to fit.
2.) Bolt holes were too small so I had to drill them out.
I think Dan really does need to correct this problem about the length thing. Enough people have complained about it.
The O2 sensor on mine had a fitment issue but if you pull out the blue rubber cover you can get some more slack and that will solve that problem.
Old Aug 24, 2001 | 03:48 PM
SPECR's Avatar
Yep, it's too long. I had the same problem. i was thinking of having a muffler shop flare out the front flange where it meets the donut so it grips a bit better as well. During the ITRExpo, more bolts rattled off, psuedo-open-header effect due to the increased length. It bugged the hell out of me so I re-installed my JDM cat...end of problem.
Old Aug 24, 2001 | 04:03 PM
New User
After I found my cat broken into a million pieces I e-mail God speed, he said that he would mail me another piece of cat. And I waited and waited and it never came.
What a crappy test pipe.
Old Aug 24, 2001 | 04:15 PM
New User
After upgrading my car I have lots of stock parts.
Here are the parts I'm selling:
1. Acura Type R intake camshaft $220
2. Acura Type R exhaust camshaft $175
3. Stock headers with heat shield $120
4. Stock exhaust $150
5. Stock cam gears $80
6. Stock catalytic converter $120
Prices so not include shipping. If you live in Los ANgeles area we can meet up so you don't need to pay shipping.
Please e-mail me at blktyper2001@yahoo.com
Old Aug 24, 2001 | 05:08 PM
sackdz's Avatar
i just bought mine, but haven't tried installing yet.. hope everything works out
Old Aug 24, 2001 | 05:28 PM
Andrew Sites's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (Austin)
I had the same problem with my God Speed test pipe too. Dan told me that Apex-i must have given me the wrong exhaust -- back when I ran the N1 system. He said that he had never had this problem with anyone else.
Old Aug 24, 2001 | 05:32 PM
New User
Default Re: DONT buy the Godspeed test pipe!!!! (Andrew)
He like to use that line, " I have never had this problem with anyone else."
I'm sticking with major stores, not these small stores.
Old Aug 24, 2001 | 05:48 PM
Todd00's Avatar
I said I don't want a title!
Ditto here. My "improved" testpipe is too long as well and it makes my exhaust stick out and rattle against things underneath the body, but he insisted that his pipes were all perfect. I even measured it against my factory cat and the testpipe was a good .5-.75" longer.
He did offer to have me send it back, but the downtime my car would have with me sending it back to him to get it modded is just too long. A replacement would be nice though. I'll just have a friend reweld it for me this winter. For the money I paid though, the piece should have fit perfectly (or at least very good) IMO.
Old Aug 24, 2001 | 06:09 PM
EPGONZALEZ's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (Todd00)
i had the same trouble with my carsound cat..too long..made my exhaust fall off the hangers and dragged my twin loop for a few laps..im much happier with my modified spoon cat jack..only way to get a perfect fit is to have the car and measure it..
Old Aug 24, 2001 | 07:48 PM
Kengs's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (EPGONZALEZ)
My Godspeed test pipe was 3/8-1/2 too long for the Si; the rear flange was pretty awful in terms of quality.
Still, no CEL for almost 6 mos. What other test pipe can make that claim?
[Modified by kengs, 4:50 AM 8/25/2001]
Old Aug 24, 2001 | 08:00 PM
Black SVT's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (kengs)
I guess I am the lucky one here then.Mine fit perfect and has had no cel for almost 8 months.I liked it so much I recomended a friend get one.He did and his had the same problems you have mentioned.
Old Aug 24, 2001 | 08:07 PM
Michael Delaney's Avatar
with respect to the length issue: can't any local muffler shop cut the B pipe, flare the end, and weld back on the flange so that everything fits?
if you look at the really fast guys here (Lip, sgt, Tony the Tiger, etc.), they all have had to adjust their length on their header and exhaust. If it was easy to hook up to the stock mounting point then what makes it any different from the limitations those points place? I mean the Hi Tech long version header does not hook up to stock mounting points and you have to extend the O2 sensor wiring. Same for the SMSP header...if you don't have Dave's adjustable exhaust, you will have to adjust your current exhaust to have the header and cat fit...the tranny mount has to be removed for some versions... do you hear people owning these headers say "oh it doesn't hook up to my exhaust so it sucks, don't buy them." ? .....
Old Aug 24, 2001 | 08:27 PM
Black SVT's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (Michael Delaney)
Bare in mind that we are talking about a supposedly plug in play direct fit test pipe.Not a $1,300 custom header.so,yes I would expect it to fit because they claim it to fit.John at hytech will tell you that there will be some fabrication involved in getting his stuff to fit.
Old Aug 24, 2001 | 08:28 PM
R134's Avatar
The problem is that you buy it because it's advertised as a bolt-on item.
Old Aug 24, 2001 | 08:30 PM
sgT's Avatar
sgT
Basically if you are serious about performance, then you
will do what it takes to get the job done.
Old Aug 24, 2001 | 09:05 PM
Bob#455's Avatar
They CAN, but most WON'T, unless you have some type of inside connection....they are too afraid of getting caught and fined a bunch of money.
Old Aug 24, 2001 | 10:28 PM
Jason's Avatar
who cares if you won't get a CEL, if it doesn't fit, you won't even have those potential problems to worry about...he doesn't seem to want to try and correct these problems...he should stop selling them until he gets them right, which obviously hasn't.
Old Aug 25, 2001 | 12:04 AM
Wet Nudl's Avatar
New User
Default Re: DONT buy the Godspeed test pipe!!!! (typer98)
My new carsound cat from SMSP fits perfect.. Don't even have to drill for the bolts to go through..
Old Aug 25, 2001 | 05:32 AM
Dipshit Dan's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (TypeRP)
I have shortenned all new pipes to 16.75 inches. Apparently the way the flange sits against the donut gasket is different than stock and throws the lengths off a bit. As for the angle of the O2, due to length of the bung I had to angle it that way to clear the shift linkage. BlkType2000, I did send you a cat piece by USPS. If you'd like another one just let me know I'll send another one out to you. You're right, the cat pieces shouldn't break. Sometimes Fed Ex manhandles the packages I guess. Anyway, I am steadily improving the design of my test pipe. Originally it was to keep the CE light happy and cure a problems which I know bug some of you (not me). I will also enlarge the holes for the rear bolts on the next batch.
Old Aug 25, 2001 | 05:51 AM
Kilohead36's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (God)
Did you take up your grievances with Dan first before posting this message? I have had Dan's testpipe for about 8months no c/e light fitment was okay...maybe you had a bad batch but I think it can be resolved if you talk to him..
Old Aug 25, 2001 | 06:49 AM
typerboy349's Avatar
Default Re: DONT buy the Godspeed test pipe!!!! (Kilohead36)
Yeah, I have to agree with Kilohead. I've had mine for about the same duration and have had 1) No CEL, and 2) Fitment was as advertised. I'm very happy with the product and the service Dan (God) provided.
Jon L.
Old Aug 25, 2001 | 07:12 AM
BryanSprinkel's Avatar
I have had the test pipe for about 6 mo's now. I am very happy, if you dont want these problems buy a $250 high flow cat. For the money the test pipe cost, it is well worth it, as well as any SMALL problems you might run into. Maybe I have one of the good ones? :~) Yes the O2 bunge is a little off, but i was able to install mine in the street in front of my house with very little problem, and i am a banker with little or no desire to get dirty, lol. :")
Bryan
