11.5 compression and stage 2 crower cam on h22a
Old Sep 24, 2003 | 06:00 PM
Chubs's Avatar
Default 11.5 compression and stage 2 crower cam on h22a
is it safe to bump the compression up to 11.5 and stage 2 crower cam???would a Vafc be alright to run??? need help
Old Sep 24, 2003 | 06:24 PM
GOLDBERG's Avatar
Default Re: 11.5 compression and stage 2 crower cam on h22a (Chubs)
how are you planning on bumping up compression?
Old Sep 24, 2003 | 07:18 PM
SilverEk3dr's Avatar
Default Re: 11.5 compression and stage 2 crower cam on h22a (GOLDBERG)
I would think so. Seeing as how thats only 1/2 point higher than type S. I would check the valve/piston clearance to be safe though. If you use a VAFC I would take it to someone who knows what there doing.(hondata recommended)
Edit: Running more compression with those cams is a GOOD thing. More compression = more Hp
Old Sep 24, 2003 | 08:20 PM
infinatenexus's Avatar
Piston to valve clearance is not an issue as long as you dont advance/retard your timing drastically.
A VAFC will tune it just fine, run 93 octain gas and you'll be of.
BTW: Be prepared for the shock of your life once you open it up for the first time
Old Sep 25, 2003 | 03:14 PM
Chubs's Avatar
wat kinda power output would i be expecting to put out once its all done???....and would the car detonate with the hight compression???
Old Sep 25, 2003 | 04:36 PM
Default Re: (Chubs)
You should be able to see 200+ whp easily. If its tuned RIGHT then there should be no problem with detonation. Def. gonna want to use 93 octane
Old Sep 26, 2003 | 08:35 PM
Chubs's Avatar
cool cant wait to take it out
Old Sep 26, 2003 | 11:21 PM
ranta18's Avatar
Default Re: (Chubs)
200 - 210 whp I'd say. We ran 200 with the stock JDM pistons and 0.020 milled head and are moving up to the Type-S pisonts now.
Old Sep 26, 2003 | 11:26 PM
alexo49's Avatar
Default Re: (Chubs)
im getting the same set-up in my 97lude, but im also getting a mildP&P...Dropping in skunk2 high compression valves as well... should i shell out the extra cash and get a multi-angle valve job?really worth it?
Old Sep 27, 2003 | 01:24 AM
Default Re: (alexo49)
If your refering to a 5 angle valve job, yes its worth it.
Old Sep 27, 2003 | 02:33 AM
kwik93si's Avatar
Default Re: (infinatenexus)
my car just dyno'd 203whp and 158tq...was at 183whp before i added the DTR side exit race header...it took a while on the dyno, but man 20whp from just a header, I'm not complaining at all. My motor is stock bottom end, w/ very mild p&p head and ferrera valvetrain, 70mm STR tb, aem intake, tuned ecu, etc...
DTR headers rock!!! I'll have pics later this weekend of the setup and chart...
Old Sep 27, 2003 | 02:44 AM
Holy mother og Gawd,, I need to do an H-22 swap,,,,
this_256
Aug 11, 2009 12:20 PM
G-COM
Aug 14, 2007 01:33 PM
red91g2
Mar 3, 2003 12:12 PM
jaredfmn
Nov 18, 2002 07:25 PM
ZColeon
Apr 24, 2002 09:21 AM
