B16A: Interference or Non-Interference?
Old Sep 24, 2003 | 04:56 PM
Waachback's Avatar
Default B16A: Interference or Non-Interference?
I have been told that by some people they are and by some they arent. Could anyone provide some solid information on this? thanks
Old Sep 24, 2003 | 04:59 PM
Jared's Avatar
Default Re: B16A: Interference or Non-Interference? (Waachback)
interference
Old Sep 24, 2003 | 05:03 PM
Patch's Avatar
Default Re: B16A: Interference or Non-Interference? (Jared)
Definately interference
Old Sep 25, 2003 | 01:14 AM
SiR Kid's Avatar
New User
Default Re: B16A: Interference or Non-Interference? (Patch)
VERY VERY interference.... See, this was because my timing belt snapped.
Old Sep 25, 2003 | 03:08 AM
1st-hybrid's Avatar
interference or non interference??
Could someone please elaborate on this.
Thanks.
Old Sep 25, 2003 | 03:38 AM
racerxadam's Avatar
Default Re: B16A: Interference or Non-Interference? (1st-hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1st-hybrid &raquo;</TD></TR><TR><TD CLASS="quote">interference or non interference??
Thanks.</TD></TR></TABLE>
wether the pistons will occupy some of the same space as the valves do at some point in the revolution of the engine. hence broken timing belts or over advanced/retarded cams can cause engine damage from pistons and valves touching each other.
Old Sep 25, 2003 | 05:44 AM
1st-hybrid's Avatar
Default Re: B16A: Interference or Non-Interference? (racerxadam)
Thank you sir
Old Sep 25, 2003 | 08:10 AM
Driven's Avatar
I don't think there's a honda auto engine that isn't interferencing...
Old Sep 25, 2003 | 08:18 AM
Vinceg99's Avatar
Default Re: B16A: Interference or Non-Interference? (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">I don't think there's a honda auto engine that isn't interferencing... </TD></TR></TABLE>
Well there is always some what of a space it just depends on how much force there is to throw the piston up into the valves. I had the timing belt break on me when I was doing 85 mph on the freeway and all I did was replace the belt and all the valves were fine. Someone that I knew that use to have a CRX was drving through a parking lot only going about 20 mph belt snapped and it creamed his valves.
Old Sep 25, 2003 | 08:59 AM
91civicDXdude's Avatar
that piston looks like the victim of something else other than the valve hitting it once. It looks like your timing was off and you drove the **** out of the car .
Old Sep 25, 2003 | 09:21 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (91civicDXdude)
naw thats just those new style super compression endyn pistons, gives you like 20:1 compression with a b19a4 head mated with a b15x3 block
Old Sep 25, 2003 | 10:58 AM
neutron91's Avatar
Default Re: (yebabee)
hahahahaha no ****
Old Sep 26, 2003 | 12:46 AM
SiR Kid's Avatar
New User
Default Re: (neutron89)
That's a stock piston when a timing belt broke at 8000 RPM during a burnout.
Sounded like a can of nails being shaken up. It broke one intake and one exhaust valve head off, and bent the other two in that cylinder. Bent the rod, and the head was garbage.
The instake valve as you can see was now a part of the piston, the exhaust valve was not to be found until we pulled the intake manifold. It fell out of the intake port.
Apparently both valves broke, the exhaust valve went up the intake port, and we found that it had gotten wedged behind the bent intake valve. Weird.
jantaasen
Sep 18, 2018 09:03 AM
211811518
Sep 21, 2006 07:40 PM
reaction360
Jul 9, 2003 12:08 PM
dclub01
Apr 21, 2003 11:45 AM
dallasyoung
Feb 17, 2003 10:29 PM
