Power Antenna questions
Old Sep 24, 2003 | 10:49 AM
T-Mo's Avatar
Default Power Antenna questions
Anyone have details about removing and installing a power antenna in a '95 Accord LX. Thanks in advance
Old Sep 24, 2003 | 10:58 AM
Okley_01's Avatar
Default Re: Power Antenna questions (T-Mo)
Well, you get to the actual motor by pulling back the carpet on the diver side of your trunk compartment and I believe that the motor is bolted down with one 10mm bolt. Once you have accomplished that, you need to remove the special nut thats located on the exterior of your car, where the mast goes through the body. Most body shops will have the special tool to remove that nut, but I was able to remove it by the use of needle nose pliers. Once the nut is removed, the whole assembly will come out.
Cm91h22a
May 23, 2015 08:33 PM
DTMamg
Jul 2, 2010 10:15 PM
ricehero
Jan 11, 2006 07:41 AM
Crasian
Sep 3, 2005 07:08 PM
wagoneer
May 1, 2005 12:56 PM
