Wanting to go 12s, most of my parts are here that Im hoping will get me there
Old Sep 24, 2003 | 07:21 AM
Casey's Avatar
Default Wanting to go 12s, most of my parts are here that Im hoping will get me there
pics speak pretty well, but in order:
99-00 si tranny
jdm 4.785 final drive kit(gsr diff gear will be here friday)
AN-R header
Momo Formula wheel(heh, dropped 7lbs off stock and it looks cool ) not that itll help my 1/4mi much
other things to note that will be different next time i go to track:
no ac
no sound deadening
no rear panels/seat belt retracts
FRONT END(look at my time and mph in sig, that aerodynamics stuff could play a role lol)
Im probably going to take out passenger seat as well.
MH 22x8x13s
Should have the car tuned with the an-r, hoping to break the 190whp barrier, and will let you know on that as well.
*edit* previous setup:
jdm gsr
toda bs
skunk2 IM
itr tb
JDM 4-1 ITR header
hondata
gsr tranny(1-2 hard to shift, 3rd gear grind)
and here is a dyno plot, you can see that my motor will definitly benefit from a tranny that keeps it in the higher rpm ranges
Old Sep 24, 2003 | 08:34 AM
GokuSSJ4's Avatar
Default Re: Wanting to go 12s, most of my parts are here that Im hoping will get me there (Casey)
92 cx 2080 lbs w/ ac and a swap
182 whp/131 wtq 8.65@81mph
13.6@97 mph
have you weighted the car after the things that you have remove ?
im sure you should ge very close if not even high 12's
Old Sep 24, 2003 | 08:46 AM
TwoRedEGgs's Avatar
Default Re: Wanting to go 12s, most of my parts are here that Im hoping will get me there (Spoon1)
i think if you get close to 200hp then you should be able to run in the upper 12's !
Old Sep 24, 2003 | 09:00 AM
advanracing62's Avatar
Default Re: Wanting to go 12s, most of my parts are here that Im hoping will get me there (TwoRedEGgs)
you should be able to hit 12s if you reduce the weight of the car a bit.. I have a 94cx 1950 w/o driver my old B16 with 162whp hit 13.2 at 3000ft elevation, my new B20 with 190whp was 12.6 same elevation.. HTH!
Old Sep 24, 2003 | 09:08 AM
eRACING's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoRedEGgs &raquo;</TD></TR><TR><TD CLASS="quote">i think if you get close to 200hp then you should be able to run in the upper 12's !</TD></TR></TABLE>
180's will get you mid 13's though you'll need to get up closer to 200 for the 12 second slip... good luck
Old Sep 24, 2003 | 09:44 AM
kwik93si's Avatar
Default Re: Wanting to go 12s, most of my parts are here that Im hoping will get me there (erics99si)
it all depends on how much your setup weighs w/ you...last year my car went 12.68 @ 105mph with only 168whp, but my car weighs 1950lbs w/ me. It went 12.41 @ 106.8mph w/ 183whp and 151tq...12.41 was with a 23x8.5x15 MH slick, they're too big for this motor just yet. the 12.6's were with a 22x8x15 MT...better gear ratio with those tires.
Old Sep 24, 2003 | 11:59 AM
Casey's Avatar
Default Re: Wanting to go 12s, most of my parts are here that Im hoping will get me there (kwik93si)
the gear ratio is what is going to help the most. 6whp and going from 22 to 20 inch slicks lowered my 1/8 by .35 seconds, or basically half a second in my 1/4 mile. If im at high 180s with the 4.7fd tranny i believe ill hit a 12. Lip said .4-.5 seconds off my 1/4 mile just from going from the gsr tranny to the tranny im using now. I think i can do it with a nice 60ft. my best to date on gsr tranny(hoping for even better with more power and better tranny now) was a 1.76, so i guess well see.
Old Sep 24, 2003 | 12:00 PM
Casey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erics99si &raquo;</TD></TR><TR><TD CLASS="quote">
180's will get you mid 13's though you'll need to get up closer to 200 for the 12 second slip... good luck</TD></TR></TABLE>
im already at mid 13s with a shitty tranny and 182whp
Old Sep 24, 2003 | 04:24 PM
kwik93si's Avatar
when my car was street driven, my old motor dyno'd at 189whp and 154tq, weighing 2200lbs w/ me it went 13.010 @ 106mph and a 1.69 60ft on a 22x8x15 mt slick
Old Sep 24, 2003 | 05:15 PM
Casey's Avatar
nice
Old Sep 24, 2003 | 07:45 PM
1 2 NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwik93si &raquo;</TD></TR><TR><TD CLASS="quote">when my car was street driven, my old motor dyno'd at 189whp and 154tq, weighing 2200lbs w/ me it went 13.010 @ 106mph and a 1.69 60ft on a 22x8x15 mt slick</TD></TR></TABLE>
sounds like that H22 tranny is killin ya. similar #s almost identical weight with less torque netted me 12.6@107 on 1.8 and 1.9 60s.
Old Sep 24, 2003 | 10:50 PM
F1Spec's Avatar
you should have already hit 12s with the power/weight u have.
Old Sep 25, 2003 | 03:44 AM
Casey's Avatar
Default Re: Wanting to go 12s, most of my parts are here that Im hoping will get me there (s2geezy)
the gsr tranny with my powerband was killing me. like i said the new tranny should make the car rip
Mr. EK9
Jan 24, 2010 08:39 PM
TexasTealEG6
Jul 20, 2009 03:05 PM
daddy
Jul 7, 2008 06:53 AM
weaksauce.org
Aug 12, 2007 07:30 PM
5lugSlug
Jul 27, 2006 05:32 PM
