Stock clutch
Old Sep 24, 2003 | 01:56 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Stock clutch
How much hp/tq can a stock b18c1 clutch handle? (hydro clutch)
The reason I am asking this is because after installing an tuning my new stage2 skunk2 cams (about 24 hours) I started to notice some strange clutch happenings, like only when shifting gears(at any rpm) when releasing the clutch pedal it kinda pops up about half way up, like it has a sticky spot and it kinda stays there, then releases... I am going out and testing it some more to get you folks a better description
Old Sep 24, 2003 | 03:17 AM
b19coupe's Avatar
Default Re: Stock clutch (92 civic VX B18c)
Stock clutch is good to about 200 whp. What kills more stock clutches is rpm as opposed to power. The springs in the clutch disc hub like to break out when subjected to repeated trips past 9,000 rpm.
Old Sep 26, 2003 | 03:32 PM
ACTman's Avatar
According to the math the torque capacity is about 186 ftlbs. Of course this varies with heat and wear, etc. The pressure plate is good to about 8500 rpm before the little retainer clips start to come off and the clutch will not disengage. I disagree with the rpm causing the spring failures as the one person wrote, but it does contribute to the wear. The window of the stock disc hub around the springs will break when you engage the clutch too hard (drag launches).
Old Sep 26, 2003 | 03:43 PM
b19coupe's Avatar
Default Re: Stock clutch (ACTman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACTman &raquo;</TD></TR><TR><TD CLASS="quote">According to the math the torque capacity is about 186 ftlbs. Of course this varies with heat and wear, etc. The pressure plate is good to about 8500 rpm before the little retainer clips start to come off and the clutch will not disengage. I disagree with the rpm causing the spring failures as the one person wrote, but it does contribute to the wear. The window of the stock disc hub around the springs will break when you engage the clutch too hard (drag launches).</TD></TR></TABLE>
Good info. Because the little window (or whatever the proper term is for it) seems to break out at high rpm, I thought that was the cause. It could well be that hard launches cause that thing to go, and then the spring pops out and can get caught between the pressure plate and the disc and cause all kinds of problems.
EJ8 GSR-T
Apr 24, 2006 09:44 AM
Stock@$$GSR
Dec 16, 2003 03:05 PM
scooter
Jan 21, 2003 11:14 AM
98cwitr
Dec 9, 2002 11:43 PM
sutats
Apr 16, 2002 09:59 PM
