What valve springs to use for all motor ls/vtec
Old Sep 23, 2003 | 11:12 PM
Blanket Jackson's Avatar
Default What valve springs to use for all motor ls/vtec
I have a friend building an all motor ls/vtec I believe and he is wondering with Toda cams what valve springs should he run Crower valve springs to be a little cheaper or should he just use TODA valve springs? I will have more info on his build up as soon as possible
Old Sep 24, 2003 | 12:13 AM
DouLik's Avatar
Default Re: What valve springs to use for all motor ls/vtec (HONDAofPOKY)
why don't you get him to buy a set of ef-1 springs and retainers? they're guaranteed against breakage if used together (springs/retainers). They are good up to 10k rpm. Not to mention, they're priced VERY aggressively for the performance numbers and guarantees they put up. PM me with any questions or concerns.
D-L-I
Old Sep 24, 2003 | 08:02 AM
MAX_CFM's Avatar
Default Re: What valve springs to use for all motor ls/vtec (DouLik Industries)
EF-1 best out there
Old Sep 24, 2003 | 08:17 AM
GokuSSJ4's Avatar
Default Re: What valve springs to use for all motor ls/vtec (MAX_CFM)
Toda valvesprings are worth the money safe to rev up to 10k with no problem
Old Sep 24, 2003 | 08:56 AM
johnzm's Avatar
Default Re: What valve springs to use for all motor ls/vtec (Spoon1)
EF-1 valvesprings are worthe the money safe rev up to 12k with no problem
Old Sep 24, 2003 | 09:49 AM
aira
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">EF-1 best out there </TD></TR></TABLE>
Old Sep 24, 2003 | 10:01 AM
EF_LSVtec's Avatar
I'd say use same brand springs/cam combo, at least for Toda cams. TODA Racing dual valve springs have specific spring rates for TODA Spec B and Spec C camshafts. TODA valve springs allow maximum lift while preventing valve float which can occur under high rpm, high lift conditions. Their specific spring rates prevents damage to TODA camshafts which may occur as a result of using valve springs that are too stiff. Valve springs which are too stiff may also put additional stress on the timing belt.
(info taken from Toda website)
Old Sep 24, 2003 | 10:40 AM
99-DC2's Avatar
Default Re: What valve springs to use for all motor ls/vtec (EF_LSVtec)
yup i second this one... hell i'm using TODA valvesprings with my SKUNK II stg 2's on my next motor...
Old Sep 24, 2003 | 10:44 AM
EF_LSVtec's Avatar
Default Re: What valve springs to use for all motor ls/vtec (93eg6)
what's wrong with Skunk2 valvesprings?
Old Sep 24, 2003 | 02:12 PM
justBLZE's Avatar
Chopper 2 Hopper
Like others said, EF-1 springs are proven to work great.
I, on the other hand, am a big fan of matching the valvetrain with cams and gears.
For example, going with Skunk2 cams get their vavlesprings, retainers and gears..etc.
Old Sep 24, 2003 | 02:23 PM
Rob Dizzle's Avatar
Default Re: What valve springs to use for all motor ls/vtec (tommySI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDAofPOKY &raquo;</TD></TR><TR><TD CLASS="quote">I have a friend building an all motor ls/vtec I believe and he is wondering with Toda cams what valve springs should he run Crower valve springs to be a little cheaper or should he just use TODA valve springs? I will have more info on his build up as soon as possible</TD></TR></TABLE>
Who is building the head?
I would listen to the person that is doing all of the work for you or talk to a good head porter/builder and go with their recomendation
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommySI &raquo;</TD></TR><TR><TD CLASS="quote">Like others said, EF-1 springs are proven to work great.
For example, going with Skunk2 cams get their vavlesprings, retainers and gears..etc.</TD></TR></TABLE>
tell me why you should match the brand of springs with the brand of cams?
u do want to match your ti retainers with the same brand of springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">EF-1 valvesprings are worthe the money safe rev up to 12k with no problem </TD></TR></TABLE>
haha, i was thinking the same thing when he said toda is safe to 10k
ill give u another
Old Sep 24, 2003 | 05:35 PM
Rocket's Avatar
Default Re: What valve springs to use for all motor ls/vtec (Bob-DC2)
I am going to do a valve spring 101 someday.
Alot of companies offer valve springs but very few get it right. Alot of springs are not properly designed and this causes problems.
I like the ef-1 the best and all our customers have been able to run extremely high rpms safely. Even on 11k mishifts.
Old Sep 24, 2003 | 05:45 PM
justBLZE's Avatar
Chopper 2 Hopper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">tell me why you should match the brand of springs with the brand of cams?
I always used to think that valvesprings are made for use with same brand cams... call me a brand **** but thats just MY preference.
Why would I wanna run Skunk2 cams with Toda valvesprings and JUN cam sprockets... let's say something goes wrong, you call Skunk2 and first thing they ask you is .. what valvepsrings were you using with our cams.. altough there's no chance you're gonna get your money back anyway, they will blame you for faulty cams. Rocket is an expemtion - great customer service.
Old Sep 24, 2003 | 05:52 PM
Rocket's Avatar
With some cam manufactures they know how much seat pressure and nose pressure to use for a certain profile. Some profiles are aggressive enough that if not enough spring pressure is use , the motor will see valve float at rpms below 5k or so.
The Honda stuff is a little easier. For stock retainers run over 70lbs at the seat to keep things happy with aggressive cams. You can run less seat pressure with lighter retainers and lighter valves.
Old Sep 24, 2003 | 07:16 PM
Big Teggie's Avatar
Go with EF-1 valvetrain
You cant go wrong
Don E
Nov 18, 2009 11:07 AM
BowSeR
Dec 3, 2001 06:55 PM
Big Teggie
Nov 10, 2001 07:34 AM
nsx-Animal
Sep 24, 2001 08:18 PM
