Need Help on H22A/Accord Set up ..
Like Topic says i need advise on what parts to use and that will work well with...here a list of the things i'am planing to get what should i change or replace or use any other company that might be better etc please some pro's with soem good Help
Info on the Car its a 1995 Accord 4 door with an JDM H22A motor and type S Tranny
MOTOR
Arias Pistons 9:0 Compression (rings, wrist pins, locks)
ReSleeving hte blcok with Golden Eagle
Crower rods
Port Polish the head
AEM Cam Sprockets ? or use another
SuperTech Valves ? or use other brand ?
Eibach Valve Springs
Crower Retainers
Head Machining ( 3 angle valve job & seals)
ARP Head studs
Cosmatic Head Gasket
TURBO
Innovative Turbo 60-! T4 Duel Ball Bearing or should i go with an T3/t4 or T4 ?
Tubular Turbo maifold
Tial Wastegate ? or should i use another brand ?
Tial BlowOff Valve ? or should repalce with something else ?
XS Intercooler ? or use other brand ?
Apexi AVCR Boost Controller ? or replace with something else ?
FUEL
RC Engineering 720CC injectors
AEM Fuel Rail
SPARK
MSD Digital 6
MSD SS COIL
MSD Coil wire Kit
ECU
Hondata S200 System
P28 OBD 1 ECU ? or use other ECU like 93 civic DX ECu ?
Motec 3 bar Map sensor ? or use something else like 300ZX TT or Supra TT ?
Modified by Showoff at 3:07 AM 9/24/2003
MOTOR
Crower rods
Crower Retainers
ARP Head studs
TURBO
FUEL
AEM Fuel Rail
SPARK
MSD Digital 6
MSD SS COIL
MSD Coil wire Kit
ECU
Hondata S200 System
Crower rods
Crower Retainers
ARP Head studs
[/QUOTE]
Personally id go with different Pistons and if you have the money get the crowers
i know of a good set going for cheap lol, if not id get other rods:
Id get Skunk2 Cam Gears.. never Aem.. bump that 3 bolt crap!!
Id personally go with Ef-1 Full valvetrain, if installed properly they even give a warrenty on their items...
Id go AEBS Head studs, if you want reasons, i can list bout ten!
Greddy BOV are nice and that is what id personally get!
last Id go with a Greddy profect b Boost controller, that damm Apexi is amazingly hard to understand and figure out
Crower rods
Crower Retainers
ARP Head studs
[/QUOTE]
i know of a good set going for cheap lol, if not id get other rods:Id get Skunk2 Cam Gears.. never Aem.. bump that 3 bolt crap!!
a wish list that come tru
need feed back what to use to the head work with what parts to use etc so many company out there JUN,Ferra, Skunk,webCams, crower ? anyone one should i go with T60 or T3/T4 looking to spool around 3-4000 rpms even 4 is ok i guess gives me time to get traction
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Showoff »</TD></TR><TR><TD CLASS="quote">a wish list that come tru
need feed back what to use to the head work with what parts to use etc so many company out there JUN,Ferra, Skunk,webCams, crower ? </TD></TR></TABLE>
do some reading and research and those 5-6 companies will be cut down to 1-3
need feed back what to use to the head work with what parts to use etc so many company out there JUN,Ferra, Skunk,webCams, crower ? </TD></TR></TABLE>do some reading and research and those 5-6 companies will be cut down to 1-3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Showoff »</TD></TR><TR><TD CLASS="quote">I know i could've bought an an 330ci or 3.2cl type s but i wanna finish what i started and why not its payed off for </TD></TR></TABLE>
cause you'll never get back what you put in to it and the you will still not be that fast in the grand scheme of things for the money you are investing. quit while your ahead.
