windshield seal....
Old Aug 24, 2001 | 09:51 AM
rioninja's Avatar
Default windshield seal....
has anyone replaced the windshield seal on their CRX? Not the glue ****, but just the rubber trim that runs around the outside. How is it held in there? is it just pressed into place, or is it glued as well? i'm just curious becaust mine is starting to lift out slightly. due to age i guess.
Old Aug 24, 2001 | 09:59 AM
cvc96honda's Avatar
New User
Default Re: windshield seal.... (RioNinja)
I just had my windshield replaced a month ago. I watched him do it. It's held in by the same sealant that seals the windshield in. It is pressed into the unhardened glue (sealant) and then dries in place.
Old Aug 24, 2001 | 12:33 PM
WuShu's Avatar
New User
Default Re: windshield seal.... (cvc96honda)
You can just buy the seal, drop push it into place and make sure you stuff it in so its water tight, then you put the sealent(glue) and just put the plastic liner/cover over it and itll hold.
Old Aug 24, 2001 | 01:41 PM
rioninja's Avatar
Default Re: windshield seal.... (HondaCRX)
Does anyone know where to buy the sealant? I'm guessing pepboys/autozone would have it, but i'm not sure what to look for.
PatrickGSR94
Feb 22, 2011 04:00 PM
B18c1vicrx
Welding / Fabrication
Jan 9, 2009 04:38 PM
jksmith
May 2, 2008 07:57 PM
KoRE
May 12, 2004 08:02 PM
94gsr
Apr 23, 2002 07:02 PM
