crx beeps..??
Old Sep 23, 2003 | 06:41 PM
ILOVEGIRLS's Avatar
Default crx beeps..??
my friend has a crx and this is his problem:
his seat belt light comes on and the door "is open" beep is on no matter what he does.
his door is shut and his belt is on. he bought the car like this and would like to fix this problem.
is there any way he can disable the beeps or the selt belt light?
thanks.
Old Sep 23, 2003 | 06:43 PM
bseriesboosted's Avatar
Default Re: crx beeps..?? (ILOVEGIRLS)
check the wires under the seat it may be disconected or broken
Old Sep 23, 2003 | 07:03 PM
Jay J's Avatar
Prince of Zamunda
Default Re: crx beeps..?? (bseriesboosted)
Or easier way take the buzzer and rip it off.... Or remove the fuses for the buzzer.
Old Sep 24, 2003 | 06:50 AM
ILOVEGIRLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseriesboosted &raquo;</TD></TR><TR><TD CLASS="quote">check the wires under the seat it may be disconected or broken </TD></TR></TABLE>
everything is fine..nothing disconnected.
where is the buzzer thing?
Old Sep 24, 2003 | 10:57 AM
90civichbsi's Avatar
im currently haveing the same exact problem, i have no idea how to fis it either....
Old Sep 24, 2003 | 12:28 PM
Outsane's Avatar
Default Re: crx beeps..?? (90civichbsi)
check the switch on the door jam.. many times the connection is just not being opened when the door is closed...
take it off.. its a phillips head and play with it..
Equal in Coffee sucks!
Old Sep 24, 2003 | 12:39 PM
njn63's Avatar
Default Re: crx beeps..?? (Outsane)
the buzzer is actually in the plastic base on the rear view mirror. If you unplug it it won't beep of course.
Old Sep 24, 2003 | 01:38 PM
ILOVEGIRLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">check the switch on the door jam.. many times the connection is just not being opened when the door is closed...
Equal in Coffee sucks!</TD></TR></TABLE>
done that already since it is the most obvious thing.
so the buzzer thing is coming from behind the mirror? it kinda sounds like it coming from the door speakers!! gRR
Old Sep 24, 2003 | 05:50 PM
byathread's Avatar
you might want to check one of your fuses. mine was making a beeping noise and it was because the battery wasent making a good connection. but check and make sure a fuse isnt burnt out.
Old Sep 24, 2003 | 06:30 PM
ILOVEGIRLS's Avatar
Default Re: crx beeps..?? (byathread)
does the fuse have a name?
Old Sep 25, 2003 | 11:43 AM
byathread's Avatar
im not sure what fuses it is? sorry all i know is i took all mine out and looked and one was burnt out and replaced it but that was awhile ago didnt even think of caring to remmeber what one it was.
Old Sep 25, 2003 | 12:13 PM
GroundZer0's Avatar
The easiest way to disable the beeps it by taking the plastic cover off that holds the mirror to the roof of your car off, Then there are a few screws on it, and what not, and you will see a plug, just unplug it, or what not. Its pretty easy to figure out once you take the cover off the mirror, the buzzer is the little plastic round piece with the hole in the middle, you can just rip it off, or you may be able to unplug it, i did mine a while ago.
austinramsay
Nov 16, 2016 01:02 AM
crxguy406
Nov 7, 2013 10:48 AM
speedtrash2
Feb 14, 2007 07:01 AM
WindyCity
Jul 6, 2006 12:12 PM
4DRPIMPIN
Mar 13, 2004 04:11 PM
