Dyno: 290 whp Stock ls
Old Sep 23, 2003 | 12:57 PM
Darin D.'s Avatar
Default Dyno: 290 whp Stock ls
Tuned my car today...
Heres the setup
Stock 95 ls longblock
golden eagle blockguard
drag manifold
garret t3/t40e
2.5" downpipe and exhaust
gm 3 bar map sensor
dsm 450cc injectors
I was running just about 17 psi and I used Crome version 0.6.8 to tune it.
Modified by Willis at 3:39 AM 4/8/2004
Old Sep 23, 2003 | 01:08 PM
QUICKERSILV3R's Avatar
Default Re: Dyno: 290 whp Stock ls (Willis)
thats an awesome number are you running that in a dx coupe or hatch?
Old Sep 23, 2003 | 01:13 PM
The Destroyer's Avatar
Thats great man, iv been thinking about boosting an LS I have. The more I read the more I want to.
Old Sep 23, 2003 | 01:20 PM
Darin D.'s Avatar
Default Re: Dyno: 290 whp Stock ls (MagillaGorilla)
im in a dx hatch.. The car is just INSANE on the highway. i get no traction until 4th...most likely due to my stock hx wheels and 185/60 tires
Old Sep 23, 2003 | 01:22 PM
HXMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willis &raquo;</TD></TR><TR><TD CLASS="quote">im in a dx hatch.. The car is just INSANE on the highway. i get no traction until 4th...most likely due to my stock hx wheels and 185/60 tires </TD></TR></TABLE>
That sucks.
Old Sep 23, 2003 | 01:23 PM
SiBirdie's Avatar
so you did that run on 17psi ?
Old Sep 23, 2003 | 01:24 PM
intekragsr's Avatar
Default Re: Dyno: 290 whp Stock ls (SiBirdie)
wow isnt that a lot for 450's?
Old Sep 23, 2003 | 01:27 PM
gitwidit's Avatar
Default Re: Dyno: 290 whp Stock ls (intekragsr)
^kinda wonderin what duty cycle is at also.
Very impressive #'s though
Old Sep 23, 2003 | 01:31 PM
Darin D.'s Avatar
Default Re: Dyno: 290 whp Stock ls (GITWIDIT)
yea i'd like to know the duty cycle too...i'm probably pretty close to maxing them out. after i saw how much fuel it needed i raised the fuel pressure to about 53 psi and pulled some fuel from the map to try and keep the injectors happy.
Old Sep 23, 2003 | 01:40 PM
SiBirdie's Avatar
So it was 17lbs of boost or is that the fuel preasure ? lolz thank you
Old Sep 23, 2003 | 01:49 PM
Darin D.'s Avatar
yea i was boosting 17 psi.
Old Sep 23, 2003 | 01:54 PM
DIRep972's Avatar
Smarter than you
definitly the rims and tires.
&lt; same power as you, heavier car, gsr tranny, bfg drag radials/gsr wheels = traction in every gear.
good job on the power
Old Sep 23, 2003 | 01:55 PM
mskibbz-T's Avatar
Awesome numbers!
Old Sep 23, 2003 | 01:57 PM
Mr. Softee's Avatar
Default Re: Dyno: 290 whp Stock ls (mskibbz-T)
thats cherry.
Old Sep 23, 2003 | 02:00 PM
SiBirdie's Avatar
Default Re: Dyno: 290 whp Stock ls (94goldjungsr)
so basically 17lbs of boost is fine on a stock ls sleves.. not bad, but I remember seeing some LS stock make close to 300whp on like 12lb of boost ? maybe im wrong. Neverless nice number
Old Sep 23, 2003 | 02:17 PM
Darin D.'s Avatar
17 psi is fine if you tune it right...conservative timing and rich air/fuel mixture are important. Also, you have to remember that not everyone has the same size turbo...so 12 psi on a slightly larger turbo may make the same power im making at 17.
Old Sep 23, 2003 | 02:31 PM
MiraiZ's Avatar
yeah, I also topped out with DSMs...I could have been in mid-300's if I hadn't gone 100% duty cycle at 7000rms...see sig
Old Sep 23, 2003 | 02:40 PM
Ri5e's Avatar
Default Re: Dyno: 290 whp Stock ls (MiraiZ)
Damn, 17 psi on pump gas? What's the A/R on teh compressor and exhaust housing? and what kind of wheel is inside that turbo?
Old Sep 23, 2003 | 02:49 PM
Default Re: Dyno: 290 whp Stock ls (Tein Man)
How much psi can the stock ls sleeves hold? With proper tuning.
Old Sep 23, 2003 | 02:50 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
290 good horsepower but i think you can get more out of it at 17 psi.
Well i guess it depends on your turbo.
Old Sep 23, 2003 | 05:03 PM
sneakypete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiBirdie &raquo;</TD></TR><TR><TD CLASS="quote">so basically 17lbs of boost is fine on a stock ls sleves.. not bad, but I remember seeing some LS stock make close to 300whp on like 12lb of boost ? maybe im wrong. Neverless nice number </TD></TR></TABLE>
SiBirdie,
Thats my car your talking about. I made 290 whp on 12 psi with garret t3/t4 turbo with 57 trim. Willis by looking at your dyno graph you look to be running a little rich between 5400-6400 rpm. You could probably pick up some more power by leaning it out a little.
Old Sep 23, 2003 | 05:08 PM
quikB18B's Avatar
Default Re: Dyno: 290 whp Stock ls (sneakypete)
Willis,
What turbo was this on?
Old Sep 23, 2003 | 05:28 PM
EH2LS's Avatar
Default Re: Dyno: 290 whp Stock ls (quikB18B)
specs? i made 300 on 12.5 with a 57 trim 60comp 63 exhaust
Old Sep 23, 2003 | 05:36 PM
turbo craig's Avatar
Default Re: Dyno: 290 whp Stock ls (Response)
so darin wanna tune my car now good **** man
Old Sep 23, 2003 | 05:43 PM
TurboJesse
Guest
Posts: n/a
Default Re: Dyno: 290 whp Stock ls (turbo craig)
nice numbers When will people understand that Boost is relative
