Installed ITR catback HUGE rattle !!
Old Sep 23, 2003 | 12:54 PM
RacerXintegra2k's Avatar
Default Installed ITR catback HUGE rattle !!
I installed the ITR catback and now i hear a HUGE rattle whenever i start the car up and its cold. sounds like its banging into one of the heat shields or somthing (metal to tin sound). anyone else have this problem ? what can i do ? is it the heat shield or could it be a crack or somthing.
Old Sep 23, 2003 | 01:04 PM
acuraholic's Avatar
Default Re: Installed ITR catback HUGE rattle !! (RacerXintegra2k)
Take the heatshield off and see if it goes away.
Old Sep 23, 2003 | 01:13 PM
fivespeedintegra's Avatar
Default Re: Installed ITR catback HUGE rattle !! (acuraholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraholic &raquo;</TD></TR><TR><TD CLASS="quote">Take the heatshield off and see if it goes away. </TD></TR></TABLE>
that's probably exactly what it is.
Old Sep 23, 2003 | 01:16 PM
JDubya's Avatar
I noticed that when i installed my ITR catback, the heatshield right under the shifter was REALLY close to the shifter/shift linkage, so i just flattened out the heat shield a little w/a hammer and it's been fine. You might wanna check that out.
Old Sep 23, 2003 | 03:43 PM
Default Re: Installed ITR catback HUGE rattle !! (ALL MOTOR LS)
so its the heat shield near the shifter got ya will check that out tomorrow mourning .. how did u flatten it out ? just banged the **** out of it with a hammer ?
Old Sep 23, 2003 | 05:34 PM
B2FiNiTY's Avatar
Did you install the donut gasket where the b-pipe meets the axle back?
Old Sep 23, 2003 | 10:11 PM
BIGGIDYBOB's Avatar
Default Re: Installed ITR catback HUGE rattle !! (B2FiNiTY)
next time you start your car, check underneath and listen where the sounds comin from. if its around the axleback... its most likely what b2finity pointed out. i ran w/out a donut gasket n sounded like metal grinding. if not... just check the heat shields
shortyz21
Jun 20, 2011 09:42 AM
SoyMilk
Jul 9, 2007 06:22 PM
JLEK
Apr 19, 2007 10:08 AM
weaselchew
Dec 16, 2002 06:11 AM
jonas
Jul 23, 2002 08:41 PM
