Ground controls vs. H&R sports
Old Sep 23, 2003 | 11:39 AM
Billy_goat's Avatar
Default Ground controls vs. H&R sports
I was wonderin which u all though were the better ones out of the set ups.
Ground control coilovers and koni yellows vs. H&R sports w/ kyb agx's
I was also thinkin ground control coilovers w/ kyb agx's
Old Sep 23, 2003 | 11:40 AM
Billy_goat's Avatar
Default Re: Ground controls vs. H&R sports (Billy_goat)
That is on a ls that is THANKS
Old Sep 23, 2003 | 11:42 AM
IntegraBoy04's Avatar
I have the H&R setup. I really like it. I don't like the Ground Control setup that much. My friend has it, and it is bumpy as hell to ride in his car.
Old Sep 23, 2003 | 02:46 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Ground controls vs. H&R sports (IntegraBoy04)
I think pairing springs w/ the right shocks is key. I have H&R Sports on Koni Yellows, and the ride sucks pretty bad over larger bumps and dips. The H&R's lowered my car 3" yet the spring rate is only 276 lb/in. I plan to change to GC's made for Konis with spring rates of around 350 in front and 400 in back. I think the stiffer springs will help make the ride a bit more controlled, and I also plan to raise the car just slightly, at least in the back.
Old Sep 23, 2003 | 03:35 PM
TimoneX's Avatar
New User
Default Re: Ground controls vs. H&R sports (PatrickGSR94)
Koni yellows are a good match with GCs in my experience. I have AGXs w/ GCs currently and though the suspension is pretty well controlled the rears have croaked once, I assume due to ride height(though it was not that low) and a very heavy stereo system outback. I intend to bite the bullet and spring for the Konis at some point.
Old Sep 23, 2003 | 03:56 PM
juggernaut's Avatar
Default Re: Ground controls vs. H&R sports (TimoneX)
I have never had koni's but always have dealt with GC I love them they are the only coilover kit available that allows you to order different spring rates in my case I had a h22 hatch with higher rate in the front and integra rate in the rear do somewhat even out with kyb gr2's and as far as the ride went it was pretty smooth other than not being able to autocross in the car I was satisfied. And the reason why your friends ride was bumpy was because he might have had the stock struts on there and of course you know stock struts arent rated for that drop besides GC are the only coilovers that come with eibach which in my opinion are one of the best springs you can get for you vehicle.
Old Sep 23, 2003 | 04:06 PM
Community Builder
Default Re: Ground controls vs. H&R sports (juggernaut)
I personally would not use any shock w/ GC's other than Koni Sports.
KYB GR-2's are only marginally better than stock and IMHO are not suitable for adjustable-height coilovers.
Old Sep 23, 2003 | 05:11 PM
Anthony K's Avatar
New User
Ground controls and Koni.
I have GC and stock shocks
Old Sep 23, 2003 | 06:37 PM
96tegls's Avatar
Default Re: Ground controls vs. H&R sports (Anthony K)
how are the ground controls with the stock struts?
Old Sep 23, 2003 | 06:44 PM
TimoneX's Avatar
New User
Default Re: Ground controls vs. H&R sports (96tegls)
Underdamped.
Old Sep 23, 2003 | 06:48 PM
gsrintegra1976's Avatar
I have ground control's and kyb agx's and the ride isnt bumpy ..I really like the setup .
Understeer
Jul 16, 2003 11:21 PM
rodimus
Mar 25, 2003 08:01 PM
EL-Driver
Apr 29, 2002 07:14 AM
HondaJon
Mar 1, 2002 02:22 PM
grngsr01
Jan 31, 2002 09:16 AM
