SRR lca's
Old Sep 23, 2003 | 11:02 AM
b18cu's Avatar
Default SRR lca's
Where do you mount the brake lines?
Old Sep 23, 2003 | 11:12 AM
skunkintegra's Avatar
Default Re: SRR lca's (b18cu)
HTH
not mine -- found in archives
edit -sorry.. n/m on me
Modified by skunkintegra at 5:40 PM 9/23/2003
Old Sep 23, 2003 | 11:16 AM
b18cu's Avatar
Default Re: SRR lca's (skunkintegra)
I dont see the brake lines anywhere???
Old Sep 23, 2003 | 01:26 PM
JDubya's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cu &raquo;</TD></TR><TR><TD CLASS="quote">I dont see the brake lines anywhere???</TD></TR></TABLE>
yea i dont think that car has ABS...
Old Sep 23, 2003 | 01:41 PM
integ22's Avatar
Default Re: SRR lca's (ALL MOTOR LS)
Does anyone know the benefits of using the SRR lca's?
Thanks
Old Sep 23, 2003 | 02:07 PM
intekragsr's Avatar
Default Re: SRR lca's (integ22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ22 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know the benefits of using the SRR lca's?
Thanks </TD></TR></TABLE>
Bling
Old Sep 23, 2003 | 02:16 PM
JCushing's Avatar
Default Re: SRR lca's (intekragsr)
maybe weight?
Old Sep 23, 2003 | 03:20 PM
blanktape's Avatar
you zip tie the abs line on the the lca.
never used the one from srr, but the ITR one is definitely better then stock integra, but then you need itr rear shocks to go with it. itr rear lca is lighter, stonger, and easy to install. my old lca is a bitch to install.. not to mention the bushing on the itr lca, way harder then the stock one.
Old Sep 23, 2003 | 07:20 PM
Project SSAP1's Avatar
what about the SPC lca's????
http://www.exospeed.com/suspension/SPClca.htm
any difference that the SRR??
Old Sep 24, 2003 | 10:34 AM
b18cu's Avatar
Default Re: SRR lca's (Project H22DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project H22DC4 &raquo;</TD></TR><TR><TD CLASS="quote">what about the SPC lca's????
any difference that the SRR?? </TD></TR></TABLE>
color...maybe weight?
Old Sep 24, 2003 | 10:40 AM
Cone's Avatar
I just ziptied mine. Working fine for the last like 4K miles. The SRR's are lighter (lightest?), stronger, and have stiffer bushings.
-Andrew
Old Sep 24, 2003 | 03:36 PM
IntegraBoy04's Avatar
Default Re: SRR lca's (Stealth 95 GS-R)
How much do these run?
Old Sep 24, 2003 | 03:41 PM
b18cu's Avatar
Default Re: SRR lca's (IntegraBoy04)
around 200 i think
Old Sep 24, 2003 | 03:48 PM
For all 4?
Old Sep 24, 2003 | 03:53 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">For all 4?</TD></TR></TABLE> just for the rear
Old Sep 24, 2003 | 03:58 PM
b18cu's Avatar
Default Re: SRR lca's (Threatcon13)
just rears...i don't think they make one's for the front.
Old Sep 24, 2003 | 04:12 PM
Oh, is that a good deal?
Old Sep 24, 2003 | 04:44 PM
JDubya's Avatar
The SPC LCA's are also a little shorter. So if you have negative camber and fix it, your tires wont rub.
Old Sep 24, 2003 | 08:46 PM
Cone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cu &raquo;</TD></TR><TR><TD CLASS="quote">around 200 i think</TD></TR></TABLE>
yup, I got mine for $211 shipped from Perpetual Concepts (they are on H-T).
Old Sep 27, 2003 | 10:09 AM
ExospeedAMcrx's Avatar
ya we have the SRR EG/DC LCA on special.. pm me if interested
Old Oct 9, 2003 | 08:40 PM
EK MONEY's Avatar
EK, abs isent even wired on the lower control arm anyway, it travels along the trailing arm assembly.
Turboed00EM1
Apr 23, 2008 02:49 PM
ballerchild
Jan 3, 2008 02:46 PM
StatGSR
Apr 28, 2005 12:55 PM
DIYaccord
82
Apr 4, 2004 08:04 PM
Drive01
Feb 16, 2004 09:56 AM
