TODA B's and Timing Belt
Old Aug 24, 2001 | 05:29 AM
FIxALPHA's Avatar
Default TODA B's and Timing Belt
My friend put Toda B's in his car (B18C1 with CTR Pistons) and have snapped three timing belts so far. The first one, he bent valves, and fortunately on the other two he did not.
Why does his timing belt snap?
Thanks
Old Aug 24, 2001 | 05:39 AM
yaksplat's Avatar
Default Re: TODA B's and Timing Belt (FIxALPHA)
I've changed two and never had a problem
Did he have the tension too high?
I didn't think it was possible, since it's self tensioning
Old Aug 24, 2001 | 05:48 AM
JDM_DOHC_SiR's Avatar
New User
MOre than likely belt was to tight.???not for sure .. as for my car I have my head cut .040 so get proper tension on my belt is kind of a pain in the A$$ it run's a tad bit loose.
Old Aug 29, 2001 | 10:39 AM
FIxALPHA's Avatar
Default Re: TODA B's and Timing Belt (JDM_DOHC_SiR)
Thanks for the info guys.....
What he did was change the cams to B16's. The car ran well with them and no problem with the timing belt. he ran a best of 13.4@100 on 15" slicks. We put in a ctr intake cam two days ago, and we are going to the track tonight at E-Town, NJ.
I will let you know what happened.
Paul
Old Sep 10, 2001 | 12:34 PM
FIxALPHA's Avatar
Finally found the problem why the timing have been breaking, because Toda B's, does not work well with JUN valve springs.
Old Sep 12, 2001 | 08:28 AM
eternal21's Avatar
Default You need to read this
You should have said that in the first place. No matter what ANYONE says, be it Toda vendor or those talking via experience, TODA RECOMMENDS THAT YOU USE THEIR VALVE SPRINGS, period dot dat. I KNOW there are vendors selling a "package" that does not use the springs, but I talked to Ali himself @ Toda. He pretty much said you take your risks if you use anything else. If anyone cares to see the mail, email me privately @ eternal21@hotmail.com
There are currently NO springs stateside. Fortunately, I snagged up the last new set about 3 weeks ago, with more not scheduled to arrive stateside for another couple of weeks. In light of current events, it may be longer than that.
[Modified by eternal21, 11:28 AM 9/12/2001]
John Z
Sep 16, 2006 10:51 PM
bet_88
Sep 7, 2006 02:49 PM
turbociv
12
May 1, 2004 06:43 AM
GQ 05YellowEVO8
Apr 5, 2003 08:11 PM
Eric R
Aug 3, 2002 02:44 AM
