92-93.. 94-95 LS ECU
Old Sep 23, 2003 | 10:07 AM
wm5holla's Avatar
Default 92-93.. 94-95 LS ECU
i cant rember. maybe you guys acan help me out. the ecu that came in the 94-95 LS was a P75? so the ecu that came in 92-93 LS was? they should both be odb1,
Old Sep 23, 2003 | 10:20 AM
jonsteR's Avatar
Default Re: 92-93.. 94-95 LS ECU (wm5holla)
92-93 = PR4 and yes it's OBD1
Old Sep 23, 2003 | 10:22 AM
wm5holla's Avatar
Default Re: 92-93.. 94-95 LS ECU (jonsteR)
does the pr4 and p75 both have the red line? and that the 96-00 LS ecu,
Old Sep 23, 2003 | 11:31 AM
jonsteR's Avatar
I not so long ago switched from a PR4 to a P75 and i can't really tell the difference in redline or fuel cut off.
Old Sep 23, 2003 | 11:49 AM
R6Elmo's Avatar
PR4 and P75 do run somewhat different codes though. The motherboard itself is different as well. but both versions will run an integra OBDI
Old Sep 23, 2003 | 11:57 AM
wm5holla's Avatar
Default Re: 92-93.. 94-95 LS ECU (R6Elmo)
i also rember hearing that the 96-00Ls ecu is also a P75
Old Sep 23, 2003 | 12:06 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">i also rember hearing that the 96-00Ls ecu is also a P75</TD></TR></TABLE>
confirmed p75 4 plugs
Old Sep 23, 2003 | 01:14 PM
wm5holla's Avatar
Default Re: 92-93.. 94-95 LS ECU (big reds)
how can u tell the differnt between the odb1 p75 and the odb2 p75
Old Sep 23, 2003 | 01:20 PM
jonsteR's Avatar
This might help
dtailspls
Northwest (Sales)
May 16, 2006 10:48 PM
prestonpark
Sep 14, 2004 10:02 PM
Nusport_racing
Apr 12, 2004 07:37 PM
Need4Boost
May 12, 2003 09:04 AM
