b16 hp non vtec
Old Sep 23, 2003 | 09:51 AM
jdmwidebody094's Avatar
Default b16 hp non vtec
Yea i was wondering, oh how much hp a b16 has non vtec. only cause the b16 i have in my car is non vtec do to a broken speed sensor... but a few ppl say it should be the same as a Ls motor, just with less torque, until i raced a LS hatch and smoked it by like 2 cars.. so if any one knows just how much power a b16 has non vtec please let me know...another problem i have is when i hooked up the vtec the speedometer started buggin out and stopped working along with the vtec.. but the speed sensor was fine before i hooked the vtec up.. now im afraid to put a new one on thinking the same thing might happen.. is there a ground or something i dont know about?
Old Sep 23, 2003 | 09:55 AM
KOALA YUMMIES's Avatar
Default Re: b16 hp non vtec (jdmwidebody094)
The B16As were all VTEC. Do you mean you're running in safe mode? So you're racing with a CEL? Or do you not know anything about the engine that is in your car?
Old Sep 23, 2003 | 10:18 AM
Default Re: b16 hp non vtec (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">The B16As were all VTEC. Do you mean you're running in safe mode? So you're racing with a CEL? Or do you not know anything about the engine that is in your car?</TD></TR></TABLE>
- Yea if you read what i wrote you might have understood everything a little better, obv. every b16 is vtec, but i said mine does not work do to a BROKEN speed sensor, which means the vtec will not engage.... good job
Old Sep 23, 2003 | 10:33 AM
R you serious's Avatar
ok, this topic is a little wierd. its probably not a good idea to be racing your car when its not working very good. however, power numbers would be similar to a zc motor
Old Sep 23, 2003 | 10:56 AM
Default Re: b16 hp non vtec (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">ok, this topic is a little wierd. its probably not a good idea to be racing your car when its not working very good. however, power numbers would be similar to a zc motor</TD></TR></TABLE>
- just to clear everything up the motor works fine, other then it not popping vtec. but thanks for the info about the ZC... i just want to know exactly how much power it has.
Old Sep 23, 2003 | 10:59 AM
You're still an idiot. It runs extremely rich in safe mode, meaning you're not getting nearly as much power, not even close to a ZC, you're also going to be getting extremely horrbile gas mileage, and you're also damaging your spark plugs.
Old Sep 23, 2003 | 11:06 AM
Well thanks captain obvious. now that you told me everything i already know, and obv your the idiot cause you still havent answered my question, think before you talk dipshit. and dont talk unless you have any info about the original question peaCe.
Old Sep 23, 2003 | 11:08 AM
What ******* difference does it make how much power you're making with your ghetto engine? Replace the ******* sensor and top ******* street racing your friends WHILE ITS BUSTED.
Old Sep 23, 2003 | 11:12 AM
swatdog's Avatar
god i love HT ownage
Old Sep 23, 2003 | 11:13 AM
well jeez thanks again captain obvious, some more info i really needed to know.. get a life
Old Sep 23, 2003 | 11:21 AM
pokemon's Avatar
His ghetto engine? LOL you must be a total moron, He isn't obviously running in safe mode that will make him run rich due to no vtec. The ECU doesn't throw any other codes but 23 I believe which is no VTEC. Therefor why would he run rich if he isn't using VTEC. It isn't like if VTEC doesn't work then the VTEC fuel and timing curves will. Instead of trying to flame someone, you could try and help them so I suggest you put the fire out on your flaming ***
Old Sep 23, 2003 | 11:24 AM
Filliam H. Muffman's Avatar
Default Re: b16 hp non vtec (pokemon)
lol. this is gonna be good.
Old Sep 23, 2003 | 11:31 AM
GSRwBOOST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">What ******* difference does it make how much power you're making with your ghetto engine? Replace the ******* sensor and top ******* street racing your friends WHILE ITS BUSTED. </TD></TR></TABLE>
whoa there tiger.. settle down...
Old Sep 23, 2003 | 11:32 AM
BeerMan's Avatar
With V-Tech disengaged your motor will run unencumbered, you should hit 200whp easy. Time to start reving on your friendly neighborhood 5.0's.
Seriously, why can't you fix it? It is anyone's guess how much horsepower you would make.
Modified by BeerMan at 4:02 PM 9/23/2003
tonesdef's Avatar
Default Re: b16 hp non vtec (GSRwBOOST)
damn i leave the board buy a corolla gts and come back and everyone is at each others throats.
Old Sep 23, 2003 | 11:33 AM
pokemon's Avatar
heh, good idea. Beside you can never know too much info. That is why you don't have the answer cause you prolly never ask questions.
Old Sep 23, 2003 | 11:35 AM
JICB16B's Avatar
maybe you should spend the time fixing the problem with you car instead of asking stupid questions like this
Old Sep 23, 2003 | 11:38 AM
Default Re: b16 hp non vtec (JICB16B)
once again if you read what i wrote and why it broke you wouldnt be talking. thanks man
Old Sep 23, 2003 | 11:39 AM
pokemon's Avatar
We are fixing the problem as of right now but we are just curious. If you don't want to answer the question don't reply.
Old Sep 23, 2003 | 11:52 AM
ERA's Avatar
ERA
Default Re: b16 hp non vtec (BeerMan)
BEERMAN WROTE: "With V-Tech disengaged your motor will run unencumbered, you should hit 200whp easy. Time to start reving on your friendly neighborhood 5.0's."
I don't buy that for a second... but it sounds good...
My guess is HP is gonna be closer to 120 if the motor is in GREAT shape less the crossover problem.... your timing curve will not alter so power and torque are obviously going to be significantly lower... retrace your wires and make sure you don't have a short somewhere too before you try to fix the problem...
Old Sep 23, 2003 | 12:46 PM
Phaze2 Mike's Avatar
Mastic and LI huh? you guys new. Ever go out to nathans in oceanside or ocean parkway? As for your motor, prob inbetween an LS and a b16, due to the fact you can still rev to 8200 as opposed to the LSs 7200. But, since VTEC does deal with oil pressure, im not sure how safe revving out is. As for your prob, get a vafc as a temp fix.
Old Sep 23, 2003 | 01:06 PM
B18Cej1's Avatar
Default Re: (Nextekhatch)
hes just curious.. right? how much hp does a b16 make minus the vtec? if i knew i would tell you.
Old Sep 23, 2003 | 01:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pokemon &raquo;</TD></TR><TR><TD CLASS="quote">His ghetto engine? LOL you must be a total moron, He isn't obviously running in safe mode that will make him run rich due to no vtec. The ECU doesn't throw any other codes but 23 I believe which is no VTEC. Therefor why would he run rich if he isn't using VTEC. It isn't like if VTEC doesn't work then the VTEC fuel and timing curves will. Instead of trying to flame someone, you could try and help them so I suggest you put the fire out on your flaming *** </TD></TR></TABLE>
If his speed sensor is broken, and "b16 is non vtec", which means he his throwing a code that would make it run in SAFE MODE thereby disableing VTEC. VTEC wont work if you have a CEL. So he is running in safe mode.
I can't believe so many people read your stupid bullshit when you dont even know how to type proper ******* english. " "
Old Sep 23, 2003 | 01:39 PM
Snoopy1's Avatar
VTEC wont work if you have a CEL. So he is running in safe mode.</TD></TR></TABLE>
Actually, I am throwing a CEL for knock sensor, since mine is bad, but my vtec still engages even when the check engine light is on. My CEL is intermittent but even when the check engine light comes on I can get vtec changeover like normal.
So Vtec isn't disabled for every CEL code. I am not saying that he might not still be running in "safe" mode, as you say.
Good try though homie
Old Sep 23, 2003 | 01:55 PM
Archidictus's Avatar
Unceasing Measure
Default Re: b16 hp non vtec (Snoopy1)
Why does the horsepower output of your broken motor matter again? If it's that important of a question, go ask the only person who could possibly know the answer: a dyno operator after he dynos your busted B16.
Glad to see that you're icy hot enough to win races on a busted engine, though .
