Timing belt changed but loud squeaking noise?
Old Sep 23, 2003 | 09:06 AM
ShaolinRider's Avatar
Default Timing belt changed but loud squeaking noise?
Not sure what the heck is the problem. Here it goes, started the car after having change the timing belt and SQEEEEAAAK!!! I'm like what the hell, is that just the belts? After driving for some time, turning off the car, and then start it back up again...theres no noise. Can someone tell me what I might possibly have done wrong or whats gone wrong? Thanks in advance.
Old Sep 23, 2003 | 10:38 AM
v4lu3s's Avatar
RTFM
sounds like loose alternator belt.
Old Sep 23, 2003 | 11:57 AM
crafty's Avatar
Default Re: Timing belt changed but loud squeaking noise? (ShaolinRider)
Is the squeak consistent?
Does it go away after a couple of seconds?
It is normal to hear a slight squeak for the first 2 weeks.....
But it is also possible that another belt is too loose.....
I would take it back to where you got it fixed and have them check it out
*Dont spray wd-40 or any other type of lubricant on the belts*
Old Sep 23, 2003 | 09:12 PM
Default Re: Timing belt changed but loud squeaking noise? (crafty)
The squeak is not consistent, and it does go away after a couple of seconds. I was told not to tighten the alternator belt too tight because it might cause the bearing to go bad on the alternator. True or False? Thanks for the replies though.
Old Sep 24, 2003 | 08:13 AM
AccVic's Avatar
I had the same problem on my f22 when I had my timing belt changed after about a month it went away
Old Sep 24, 2003 | 09:27 AM
david90's Avatar
squeak happens when the belt is on too tight not to loose. loose belt makes slapping sounds
jdmme09
Feb 15, 2009 06:16 PM
92coupe
Dec 17, 2008 12:08 PM
VTECth1s
Aug 30, 2006 10:24 PM
flat-blk-HB
Apr 17, 2005 06:10 AM
.Noah Fecks
Feb 8, 2005 12:31 PM
