help removing axle
hey,
usually i don't have a problem removing my axle, but today i can't seem to get it out. I need to get the driver side axle out because i'm putting a new hub/spindle on. any tips besides beating the **** out of it???
tia
tia
its stuck on the tranny side but i'm not taking the axle completly out, i'm just trying to remove it from the hub side so i can take the spindle out and replace. it's almost coming out but its being a little bitch and doesn't want to. i don't have a prybar with me, i'm trying to do this at my apartment and all i have are basic tools. help please, are they're any tips or just beat the **** out of it until it comes out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">Flathead screwdriver between the axle and the tranny, pop it out. How I always do mine.</TD></TR></TABLE>
Ditto!
Ditto!
OK, wait. You are trying to remove the AXLE to replace the Hub???
You should be able to just remove the 32mm Retainer ON THE HUB, and a 17 MM at the top and bottom of the spindle. that will have the hub handed to you...
Don't forget the brake lines and that there is a GIANT C clip holding that hub in place when you get it on a press. I trusted a friend took out that C-Clip, and I put nearly a ton on it before it gave. C Clip took out a hunk of concrete floor that can hold a drink of water.
If that had been my leg...
Scott
Scott
ok i finally got it. i was trying to take the axle out so i could put the hub and new spindle on, i wasn't just replacing the hub. but yea, i got it after a bunch of cursing and beating of my baby!
thx for the help guys
