Momo wheel installation problems
Just bought a Momo Formula steering wheel off a friend of mine. Put it on, but my turn signals dont turn off automatically, and had to trim the plastic around the hub for it to fit. Is this normal? Also what do i need to do to get my horn to work? thanks for any help
this is not normal...assuming the hub you have is for a honda..you should not have run into any problems with making it fit... as far as the horn, i run a quick release so i just use a secondary aux button for a horn....
i bought a hub that the seller told me works with a dc or eg, and the splines are the right size for sure, it slips right on them.
its a momo hub. I had to shave off some of the plastic trim on the interior thats around the hub so it would snap back together.
yeah the hub isnt reaching the white plastic piece that contacts the turn signal arm, no matter how hard i try to push the hub on it wont go any further
my momo wheel/hub has no problems. install was easy. in fact i think my sister did it. (j/k) my horn doesn't work tho. i just ran a wire and mounted a black button kinda hidden.
MASTRCHANN
Aug 23, 2005 04:26 PM
