swapping rear disc in99dx, with teg ABS work ?
Old Sep 23, 2003 | 05:25 AM
TheAutoboxer
Guest
Posts: n/a
Default swapping rear disc in99dx, with teg ABS work ?
glooming threw the net, i came upon this..
1996
Rear Suspension
Acura Integra 3HB,ABS.DISC-TYPE AD0006 $250
think i should get it, i have a 99 dx sedan. I want disc's all around, teg/etc susspension.
Old Sep 23, 2003 | 06:18 AM
monicle's Avatar
Default Re: swapping rear disc in99dx, with teg ABS work ? (menkio)
itll work for you i swapped 96 gsr stuff into my 2k hx and theres no problems some people say you should switch the prop. valve but i never did and they feel great
Old Sep 23, 2003 | 06:38 AM
Echo7847's Avatar
Default Re: swapping rear disc in99dx, with teg ABS work ? (monicle)
If you do get them be sure and remove the abs unit that prevents the hub from spinning. I got mine from a gsr as I had to do the same. Here's a pic to show ya what I'm talkin about.
There were like...4 10mm bolts hoding it onto the hub, after that it'll come right off.
geebs
Mar 2, 2009 03:02 PM
mrbigg9032
Suspension & Brakes
21
Dec 8, 2008 08:01 PM
deans96ek
Apr 15, 2007 08:46 AM
gulftiresinc
Jan 7, 2006 11:50 AM
DC4_MADMAN
Oct 22, 2005 02:05 PM
