ecu codes, light always on? wiring problem?
Old Sep 22, 2003 | 09:38 PM
pleasuretool's Avatar
Default ecu codes, light always on? wiring problem?
car won't start, trying to find promblem...
my ecu light comes on in the "II" position, and stays on while i try to start the car... The CEL is NOT on... what does thsi mean?
normally the ecu light should go off, correct? i did the DPFI -> MPFI re-wire, so it's possible i screwed up.
I have a3-a7 going to injectors
c1-c2 going to the cam sensor in the dist.
and b10-b11 hooked to the orange/white wires.
thanks
Old Sep 22, 2003 | 09:44 PM
EG8R's Avatar
Default Re: ecu codes, light always on? wiring problem? (pleasuretool)
Copy and paste the link below.... Follow that pic and see what you have....
http://www.imagestation.com/pi...g.jpg
Old Sep 22, 2003 | 10:01 PM
Default Re: ecu codes, light always on? wiring problem? (skelly ed6)
yeah i think i may have the dist wired up wrong.
my C2 is going to a blue/yellow. there is no orange/white wire on my dist plug.
the rest i matched colors, so i will fix c3/c4 right now and see what happens.
these wires mixed up would cause the car not to start, correct?
Old Sep 23, 2003 | 11:36 AM
i think your diagram is wrong. everywhere else says:
C1 -> blue/green
C2 -> blue/yellow
can anyone confirm?
Old Sep 23, 2003 | 02:34 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
If the check engine light remains on when cranking,
Check fuse #14 labeled alternator solenoid...
If that fuse is blown,the fuel pump does not come on..
wiring:
http://www.angelfire.com/d20/h....html
Old Sep 23, 2003 | 05:09 PM
Default Re: ecu codes, light always on? wiring problem? (88DXCRX)
naa i'm getting fuel to the rail. and spark plugs are sparking... but no ignition is taking place... i'm pretty sure injectors are not getting signal.. what could cause that?
I bought a multimeter today and i'm about to use it on the plugs...
Old Sep 23, 2003 | 06:48 PM
EG8R's Avatar
I didn't make the diagram.... It worked for me.
Make sure your injector resistor box is hooked up to 2 yellow/black wires.
crookson speed
Feb 19, 2014 01:32 PM
z6hatchboy
Sep 16, 2010 04:16 PM
cuseikan
Aug 18, 2008 01:26 PM
integ69
Mar 14, 2006 09:31 AM
